Oxygen sensors and catless down pipes
So I posted this question in the DIY thread, but am going to ask the question again here to keep the DIY on topic. Mods you can delete those posts if you want.
Copy/Paste:
If I am installing catless down pipes and JHM tune, are the o2 sensors really doing anything? I know the rears just measure cat efficiency, so those shouldn’t really matter with the tune, correct? Are the fronts still working as they should? I have a CEL for B1S1, and am wondering if I should replace both front o2 sensors before flashing the tune or if it will override the sensors? I just don’t want to drop $4-500 for all four o2 sensors if I don’t have to.
justincredible responded with this:
[quote]I would suggest starting a post on this in the main section. But anytime you have a S1 code you need to replace the sensor. Those are the more important ones. The rear 02s control more then just checking to see if you have cats. They help test the health of the primary 02s they also help with fuel mileage and a few other smaller efficiency things. They are important. Of you change a sensor on one bank it’s a good idea to change the other one to.
So my follow up question is this:
Do you mean the same sensor on the opposite bank? or sensor 2 on the same bank?
I know the front o2s are the most important, I want to make sure everything is up to snuff before I purchase/flash the JHM tune and I want to do the o2 sensor(s) when I install the trexturk dps I have in the storage shed. I just don’t want to be spending any unnecessary money since I spent way too much Christmas shopping. The dps I bought used and they came with a 90 degree spacer on the rear o2 port. My mechanical background comes from the off-road side of the house and emissions stuff usually gets ripped out so I am new to this. I apologize in advance for any seemly obvious questions.
