I got my car back, and after putting in a new battery, everything runs smoothly at speed. However, I still get occasional rough idle and these faults while the engine is cold:
P0023 - “B” Camshaft Position - Actuator Circuit/Open Bank 2
P1060 - Bank 2, cam shaft adjustment discharge opening, interruption
I’ve had these codes forever, they seem come and go, but now it seems they’re here to stay. What does the VVT/cam solenoid actually do while the engine is cold?
I’ve already done the following:
- The 2-pin wiring for both intake/exhaust cam solenoids on the driver side were falling apart and replaced with new connectors
- the exhaust cam solenoids were swapped between the driver/pass side
Even after these changes, I still get the code on “B” Camshaft Position. Previously, I assumed Bank2 is the driver side and “B” refers to the exhaust cam solenoid because the wiring there was clearly damaged. But after the new connectors and solenoid swap, I was assuming the problem would go away or follow a bad cam solenoid. Unfortunately, it has stuck with Bank2/B.
any thoughts?
