Thanks so much for the reply. Carbon clean has been done along with a new manifold by the dealer previous owner relatively late mileage. There were a few electrical oddities, including sunlight sensor and alarm, both of which seem to be working fine now. Repaired a found broken and shorted wire leading to the hood release and the hood stopped releasing. Works fine again after manually releasing (that was interesting but ended very well without a scratch).
Injectors are on the maintenance list, but you have an interesting point. Considering dealer service I hope they would would done the fuel filter. Are there other common ways of contaminating the fuel system? My experience has been if an injector starts to go you can swap the bad one by trial and error correcting the idle once found even if no code. Are the pumps not pumping fuel TO the injector? How could a dirty injector plug a pump. Thanks again. All codes below.
Monday,09,January,2017,21:17:27:17230
VCDS – Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.0.0 (x64)
Data version: 20170106 DS267.0
www.Ross-Tech.com
VIN: WAUDN74F88N076782 License Plate: AUDI S6
Mileage: 166110km-103215mi Repair Order:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 11 31 13 15 16 17 19 1E 36 37 42
46 47 4F 52 53 55 56 5C 61 62 65 67 6C 72 76 77
VIN: WAUDN74F88N076782 Mileage: 166110km-103215miles
07-Control Head – Status: OK 0000
08-Auto HVAC – Status: Malfunction 0010
0F-Digital Radio – Status: Malfunction 0010
11-Engine II – Status: OK 0000
31-Engine other – Status: OK 0000
13-Auto Dist. Reg – Status: OK 0000
15-Airbags – Status: OK 0000
19-CAN Gateway – Status: Malfunction 0010
1E-Media Player 2 – Status: OK 0000
55-Headlight Range – Status: OK 0000
56-Radio – Status: OK 0000
5C-Lane Maintain. – Status: OK 0000
61-Battery Regul. – Status: Malfunction 0010
65-Tire Pressure – Status: OK 0000
76-Park Assist – Status: OK 0000
Address 01: Engine (BXA) Labels: Redir Fail!
Part No SW: 4F1 910 562 A HW: 4F1 907 552 B
Component: 5.2L V10/4V FSI ª0010
Revision: 5HH02— Serial number:
Coding: 01050009190F0260
Shop #: WSC 26097 444 83501
VCID: 234E156AE296B659F2-8076
2 Faults Found:
000135 - Fuel Rail/System Pressure
P0087 - 002 - Too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 5
Reset counter: 255
Mileage: 166025 km
Time Indication: 0
Date: 2017.01.07
Time: 14:28:42
Freeze Frame:
RPM: 3142 /min
Load: 33.7 %
Speed: 114.0 km/h
Temperature: 93.0°C
Temperature: 18.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.097 V
P0087 - 008 - Too Low - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 166029 km
Time Indication: 0
Date: 2017.01.07
Time: 14:31:01
Freeze Frame:
RPM: 3017 /min
Load: 46.3 %
Speed: 111.0 km/h
Temperature: 96.0°C
Temperature: 18.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.224 V
Readiness: 0000 0000
Part No SW: 4F5 910 156 F HW: 09E 927 156 C
Component: AG6 09E 5,2 FSI USA 0020
Revision: --H04— Serial number: 0113891
Coding: 0000002
Shop #: WSC 02325 758 00200
VCID: 2B5EFD4A8A467E194A-807E
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Coding: 0020920
Shop #: WSC 34412 001 1048576
VCID: 3162EF22A86A14C970-8064
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 A HW: 4F0 905 852 C
Component: FBSAUDIC6 ELVSG H01 0040
Revision: 09010701 Serial number: 10601600909336
Coding: 0000007
Shop #: WSC 02323 758 00200
VCID: 244C1676E798B1618B-8070
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 D HW: 4E0 035 729 A
Component: Interfacebox H43 4140
Revision: 00000000 Serial number: 361K 077518548
Coding: 0010003
Shop #: WSC 02335 785 00200
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000000917414
Subsystem 3 - Serial number: 0107.11.070000000100010578ÿ
Subsystem 4 - Serial number: 010578ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000053 Serial number: 00000000463367
Coding: 0524330
VCID: 1C3C2E96DFE889A133-8048
1 Fault Found:
00797 - Sunlight Photo Sensor (G107)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 124
Reset counter: 210
Mileage: 164525 km
Time Indication: 0
Date: 2016.12.02
Time: 23:25:15
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H18 0250
Revision: 00000000 Serial number: 4F0907279
Coding: 0115103
VCID: 3064EA26A3601DC17F-8064
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0100
Coding: 00150573
Shop #: WSC 02335
Address 0E: Media Player 1 (R192) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H15 0700
Revision: 00000000
VCID: 2756017A56AE5A79AE-8072
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 K HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0140
Revision: 00000000 Serial number: AUZ4Z7G0190891
Coding: 0000100
Shop #: WSC 00000 000 00000
VCID: 2F66E95ABE5E023966-807A
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 4
Reset counter: 160
Mileage: 165757 km
Time Indication: 0
Date: 2016.12.30
Time: 16:52:52
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4F0 910 561 C HW: 4F0 907 561 B
Component: ABSTANDSREGELUNGH02 0020
Revision: -------- Serial number: 00000000000000
Coding: 0041118
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 K HW: 4F0 959 655 D
Component: 7Q AIRBAG AUDI8RH30 0400
Revision: 02H30000 Serial number: 003BMD020K4W
Coding: 0014161
Subsystem 1 - Part No: 4F0 910 339 B
Component: BF-Gewichtsens. H03 0060
Subsystem 2 - Serial number: 6332CSME3401583E%
Subsystem 3 - Serial number: 6342CSME30342B67+
Subsystem 4 - Serial number: 6352QSME4561383BI
Subsystem 5 - Serial number: 6362QSME46012E35D
Subsystem 6 - Serial number: 63734SME4567225B0
Subsystem 7 - Serial number: 63834SME155A2260X
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90025072990165
Coding: 0032151
VCID: 2756017A96AE5A79AE-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H01 0030
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 981 S
Component: KOMBIINSTR. M73 H21 0240
Revision: 00700000 Serial number: 73356XR97
Coding: 2257203
Shop #: WSC 47338 001 104857
Address 19: CAN Gateway Labels: 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 C
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1000D07818801A
Coding: F5D5DEF7737A0600
Shop #: WSC 02335 758 00200
VCID: 2D5AF352B452702954-8078
1 Fault Found:
02095 - Component Protection Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 185
Mileage: 165456 km
Time Indication: 0
Date: 2016.12.20
Time: 09:25:16
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
Component: MP3-Changer H46 0350
Revision: 00046006 Serial number: AUZ5ZBG3510145
VCID: 183432862BD0E58117-804C
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: 61C25F62B80AE449A0-8034
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 F HW: 4E0 919 887 M
Component: MNS US H50 0990
Revision: 00000000 Serial number: 395J-077505274
Shop #: WSC 22129 444 52429
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0210
Revision: 00000000 Serial number: Qˆ"
Coding: 0051947
Shop #: WSC 02327 758 00200
VCID: 2C5CFE568F48792143-8078
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
Component: Komfortgeraet H26 0210
Revision: 02100026 Serial number: 01076274210000
Coding: 4618397
1 Fault Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 173
Mileage: 161132 km
Time Indication: 0
Date: 2016.08.25
Time: 06:34:24
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H10 0240
Revision: PROD_01 Serial number: 00000000059240
Coding: 0000026
Shop #: WSC 02323 785 00200
VCID: 254A0B72ECA248699C-8070
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 C
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000037128
Coding: 0012014
VCID: 5EB8649E8974DBB19D-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0210
Revision: 00000000 Serial number: „G"
Coding: 0052075
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04—
Coding: 0008022
Shop #: WSC 02145 785 00200
VCID: 20441A66F380AD41EF-8074
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000016
VCID: 2952074280BA6C09B8-807C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 394K4077830887
Coding: 0000002
VCID: 2E58F45EB9540B316D-807A
Address 5C: Lane Maintain. Labels: None
Part No SW: 4E0 910 217 C HW: 4E0 907 217 C
Component: J759 LDW H06 0070
Revision: 00H06012 Serial number: 400207A24000DC
Coding: 0000103
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
Component: J0644 BEM H12 0760
Revision: 00000000 Serial number: 00000000029947
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 340612C0A4
Coding: 344630393135313035442056413033343036313243304134
Shop #: WSC 47338 001 1048576
3 Faults Found:
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 165796 km
Time Indication: 0
Date: 2017.01.02
Time: 18:21:33
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 165796 km
Time Indication: 0
Date: 2017.01.02
Time: 18:27:59
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 165796 km
Time Indication: 0
Date: 2017.01.02
Time: 18:28:09
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0210
Coding: 0051754
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000600058526
Coding: 0062725
VCID: 2240106EFD8CBF51F9-8076
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H46 0630
Revision: 00000000 Serial number: 00000710240275
Shop #: WSC 12336 024 394758
VCID: 346CE636577821E11B-8060
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12— Serial number: 525PA8-J7X20HA
Coding: 1000204
VCID: 5DBA63928472C0A984-8008
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0210
Coding: 0051754
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06240730200374
Coding: 0021306
Shop #: WSC 131071 1023 2097151
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 E HW: 4E0 862 335
Component: Handyvorb2 H18 0950
Revision: 00000000 Serial number: 00000005014673
Coding: 0010900
End-------------------------(Elapsed Time: 03:18)--------------------------
