I’m getting sporadic EPC faults along with these OBD codes (as reported using Carista)
P0221 - Throttle Position Sensor B (G188), Circuit Range / Performance
P0221 - Throttle/Pedal Position Sensor/Switch “B” Circuit Range/Performance
If I reset the codes, the car seems to drive fine – until the next time the fault pops up.
At first it was happening on cold starts when the car was parked outside at night. We thought it might be a battery issue because I was also getting these faults:
P0024 - “B” Camshaft Position - Timing Over-Advanced or System Performance Bank 2
02272 - Static (Quiescent) current stage 1
02273 - Static (Quiescent) current stage 2
02276 - Static (Quiescent) current stage 5
02274 - Static (Quiescent) current stage 3
But we replaced the camshaft sensor, found/fixed a loose connection in one wire to ECU2, and also cleaned & zip-tied the throttle body connector to ensure a solid connection. I no longer get these faults, and the car starts up fine when it’s freezing cold outside.
But the P0221 still pops up sporadically, only this time it happens after the engine is warm. I found this page
http://wiki.ross-tech.com/wiki/index.php/16605/P0221/000545
Which mentions a “TSB 97-08-25 or 2018260 for a wiring repair at the Throttle Body” for A6 FSI engines. Does anyone have ideas or experience with this?
