P0480 Radiator fan keeps running
I just finished the JHM supercharger install. The driver side radiator fan runs continuously while the car is running then 10 more minutes after the car is shut off. VCDS showed P0480 code. Checked the harnesses from the radiator to the JHM harness extensions. All seems good. Coolant level is appropriate. Has anyone had experience with this issue?
