P0741 - Torque converter going out
3.0 QTip my torque converter is going out. I have an intermittent P0741 CEL
So, I’m going to get at it sooner than later.
What other things should I do/replace as long as this job is going on?
I will check/ replace trans mounts, for example.
Thanks all
I just replaced the torque converter on my mother’s 3.0 a little while ago. So I would change your trans fluid and strainer, check the trans output shaft seal to see if it is leaking center diff oil, look over the front CV boots (inner and outer), check all the mounts (snub, engine, and trans), and it is a great time to install JHM downpipes.
thank you! i will definitely do all those
