I ran a scan and got P1573 error (the only error found during the scan).
I don’t have any obvious engine mount related issues that i can tell, i wanted to check the connection first, but don’t know where to look. Anyone have a picture, or diagram that shows the connection?
I do have SAI delete, but this issue did not follow that, delete was done a few months back, this issue has been going on for a few weeks.
The only issue I have been having is in the morning on cold startup, car runs fine in park, until I put in any gear, then it runs very rough for about 1/2 mile but no cel. Then car seems fine. What i have done is to put in gear, put in park, wait about 30 seconds, and it clears out and i can drive normally. I wouldn’t think these are related, but i’ve been around cars too long to think it’s impossible.
Part No SW: 4F1 910 562 A HW: 4F1 907 552 B
Component: 5.2L JHM/V3 9XSI ª0010
Revision: 5HH02— Serial number:
Coding: 01050009190F0160
Shop #: WSC 41966 000 1048576
VCID: 234597C8E2ACAD5EB7-8076
1 Fault Found:
005491 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 12
Reset counter: 255
Mileage: 187140 km
Time Indication: 0
Date: 2017.07.14
Time: 08:17:35
Freeze Frame:
RPM: 629 /min
Load: 23.9 %
Speed: 4.0 km/h
Temperature: 87.0°C
Temperature: 22.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.097 V
