I’ve recently been getting a P2098 code which triggers the CEL. I scanned it and cleared it with a cheapo code reader I keep in the glove but after 250 miles it has come back on. After looking at the live data on the reader I noticed my long term fuel trims are out of whack as well. Bank 1 was around 9% and bank 2 was 0%. O2 sensors have about 30k miles on them and the readings seemed to be within the parameters that were given in the (cheap) scan tool. What’s the best course for resolving these issues? Do you think they are related?
Car has 111k miles on it, has been running great and just got checked over for vacuum leaks.
Here’s my findings with VCDS today.
008344 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 2
P2098 - 002 - Too Lean - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 179126 km
Time Indication: 0
Freeze Frame:
RPM: 2156 /min
Load: 11.4 %
Speed: 69.0 km/h
Temperature: 90.0°C
Temperature: 5.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.843 V
Not sure if these were the right groups to log but they are a couple 3rd gear pulls.
https://docs.google.com/spreadsheets/d/1Flc4LslRRSmFkKrpZVQ69J88xc17v5atQKnNKkjynLo/edit?usp=sharing
16:39:10 Group 003: General
760 /min Engine Speed (G28)
6.64 g/s Mass Air Flow Sensor (G70)
0.8 % Throttle Valve Angle
6.0 °BTDC Ignition Timing Angle
16:39:10 Group 002: General
18.8 % Engine Load
3.28 ms Injection Timing
6.69 g/s Mass Air Flow Sensor (G70)
16:39:10 Group 032: Lambda Control (Mixture Adaptation)
-2.6 % Adaptation (Idle) Bank 1 Sensor 1
9.4 % Adaptation (Partial) Bank 1 Sensor 1
0.0 % Adaptation (Idle) Bank 2 Sensor 1
0.0 % Adaptation (Partial) Bank 2 Sensor 1
