Bear, thats pretty low, usually the reservoir is sized for the pads/piston travel, you should get the pad sensor warning before the low fluid. If you add more fluid, tell the shop who does the brakes so they don’t overflow your reservoir when the compress the pistons back in the calipers…
Yeah, I have a set of 18" reps with snows (previous owner’s) that would NeVER fit over the Brembos. I found these 18x8.5 ET35 Forgestar CF5s for a $grand, totally mint, with hankook v12s (I hate these tires). I swapped the tires between both 18s, I keep the Forgestars with the snows, and my bro gets my old reps with the Hankooks that perfectly fit his A3 TDi.
why did I think Forgestar CF-5s would fit? I PMd Tahoskier and discussed, he is running the brembos with CF-5s, 18x9 ET43, with a 5mm spacer (total ET38). I lose 6mm with the 1/2" narrower wheels, but I’m already at ET35 so I figured another 3-5mm of spacer and I’m golden. NOPE. I stacked 13mm of spacers until I had about 2mm clearance to the calipers. The poke was so ridiculous, I lol’d for a while. Then I said fuck it, I’ll go with the stock brakes for the winter…
The clearance issue was getting more offset clearance to the raised “barrel” where the spokes meet. There was tons of room from the spokes themselves.
I’m not too upset, since i got these for less than a set of winters, my three hours are free, ATE super blue is cheap and my wife has gotten good at working the pedal to bleed the brakes. But there goes my plan for a set of light track wheels that I don’t mind banging up at the track…Plus I’m running out of room…at last count I have 8 sets of wheels at my house that aren’t mounted on a car.
