Passenger Seat Related Fault Codes
Hi Guys,
My airbag light is on, and when I cycle through the codes on VCDS I get a different one every time. Almost all of them related to the passenger seat. There is one outlier that comes back periodically which is one of the front crash sensors. I switched it from the driver side to passenger, and the code stating MIL on moved to the passenger side, so that should be a straight forward fix. The seat however has me baffled, please see the codes below; please keep in mind i copied these into a text file one by one because these faults did not come up simultaneously but rather separately each time i would scan. It is my understanding that the Audi service bulletin relating to seats was in fact launched for the driver side seat, and more specifically for the 01217 side airbag igniter code, as seen in the audizine DIY http://www.audizine.com/forum/showth...(Audi-TSB). As you can see below, I do not have this code, nor is it in the driver side seat. My question is, should i go ahead and try the simple diy on my passenger side seat anyways or do you folks think I would be going after the wrong circuit in the seat?
Air Bag Codes:
Sunday,28,December,2014,14:55:18:15433
01731 - Switch for Seat Height Front Pass. Seat (E65); Down
011 - Open Circuit - MIL ON
1 Fault Found:
01725 - Switch for Seat Position; Pass. Seat (E64); Back
1 Fault Found:
01724 - Switch for Seat Position; Pass. Seat (E64); Forward
1 Fault Found:
01732 - Switch for Head-Rest Adj. Pass. Seat (E170); Up
1 Fault Found:
01736 - Potentiometer for Mirror Adj. Vertical; Drivers Side
1 Fault Found:
01729 - Switch for Seat Height Rear Pass. Seat (E66); Down
1 Fault Found:
01728 - Switch for Seat Height Rear Pass. Seat (E66); Up
1 Fault Found:
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
