Address 01: Engine Labels: 06C-909-559-ASN.lbl
Part No SW: 8E0 909 559 D HW: 8E0 909 059
Component: 3.0L V6/5V G01 0003
Coding: 0016711
Shop #: WSC 63351 000 00000
VCID: 366722EB38D7
2 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded - MIL ON
16685 - Cylinder 1: Misfire Detected
P0301 - 001 - Upper Limit Exceeded - MIL ON
Readiness: 0000 0001
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04495
Shop #: WSC 06435
VCID: 2647F2ABE877
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 F
Component: A4 Klimaautomat 0712
Coding: 00000
Shop #: WSC 63351
VCID: 2443E8A39E4B
1 Fault Found:
00819 - High Pressure Sensor (G65)
07-10 - Signal too Low - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00011
Shop #: WSC 00000
VCID: 346318E32EAB
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 A
Component: Airbag 8.4E 4000
Coding: 0010607
VCID: 356525E725D1
Coding: 0016711
VCID: 366722EB38D7
2 Faults Found:
Coding: 04495
Shop #: WSC 06435
VCID: 2647F2ABE877
Coding: 00000
Shop #: WSC 63351
VCID: 2443E8A39E4B
1 Fault Found:
Coding: 00011
Shop #: WSC 00000
VCID: 346318E32EAB
Coding: 0010607
VCID: 356525E725D1
Coding: 0016711
VCID: 366722EB38D7
2 Faults Found:
I swapped the coils on cylinder one and the codes didn’t move, it only came back with a 3rd new code…
17763-Ingition Circuit-Open cirucit
P1355–004-No Signal/communication
Upon start after clearing codes I can’t even drive 20 feet without CEL flashing and engine is rough and shaking pretty bad, I dont understand why its shaking so bad for just 1 bad cylinder. I wonder if this could have anything to do with my lifter ticking, i was thinking not cuz its not even ticking that bad and as you can see from the camshaft pics in my thread the wear is not even that bad.
Please help I had to have it towed again for the 2nd time, THis is STRIKE 2 on this bitch. I swear one more and I’m going to have to… well no I won’t because I love this car and will take it to the grave but I just want it back puuring like it used to when I first bought it. Guess I shouldn’t of spent so much time on cosmetics and kept a little more up on motor work cuz it seems to have caught up and is kickin my ass around the block!
