Thanks for the reply! I’ve heard that it’s “better” to get everything done first and then get the tune so it can learn everything. My car is scheduled for the 20th to get the downpipes out but I was thinking I can get the tune from now to then since its 2 weeks away. I’m afraid that if I do tune first with my 2.5 exhaust now and then get piggies I wont notice the piggies or the power overall lol it sounds stupid but I’m pretty skeptical when it comes to this unless I have dynoed before and after or there is a HUGE hp increase. Piggies are good for longevity of the engine anyways right?
When you see tons of JHM supporters its due to the amount of time and support JHM puts into these cars. The tune is one thing that leaps and bounds is beyond every other companys tunes. Either way you cant go wrong. Yes piggies are something that helps with motor life and helps reduce the chance of cylinder wall warpage and scoreing. There is truth to the fact that if you dont reset your ecu it wont get a chance to learn and adapt all the way right away. Over time it can. To reset the ECU all you do is to disconnect the batt and touch the batt terminals together for 45 seconds to disscharge the system.
I believe Jake mentioned this before where its better to go up and try to avoid going down. Meaning if you have 91 tune then it’s perfectly fine to fill up with 91 or higher like 93. Where it’s not such a good idea to get 93 tune and not being able to fill up with and have to use lower octane fuel. You probably would have to take it easy until you burn off that lower octane gasoline. As justinincredible said it’ll pull back on safety. Personally if I wouldn’t be able to fill up with proper fuel all the time then it’s better to get 91 octane tune so you don’t have to think about things like that.
On the topic of making power, has anyone ever thought about getting a JHM stage 1 kit, installing it, but also installing a set of Integrated Engineering 4.2 rods and getting a custom smaller pulley made for the blower from a company like the pulley boys to make in the neighborhood of 500+ whp without going balls to the walls stage 2 600+ whp
Theoretically it’s possible, but it would also probably grenade your BHF shortly after that. Stage 1 is already maxed out at the safest level possible. That’s why any more power than that, it requires a built bottom paired with their hd heads. I personally wouldn’t risk it just for a little more power. Risk to reward ratio is not in your favor.
Here is where all the walls fall down. We have a great motor but only to a point. The JHM kits make about 450whp and are good for a solid 11.x pass very close to what you would see out of the much more potent RS4.
But here is where things fall apart. The issue with our motor isnt actually the rods. Its the pistons. The pistons if pushed too hard will expand at a faster rate then the cylinders. This is one of the major reasons behind doing piggies as it helps remove cylinder heat faster. So the pistons expand too quick and then the get trapped in the cylinder and bam the rods snap at the neck where they are the weakest.
You can just replace the piston but the rods have a serious neck down at the wrist pin and that makes them weak. So its pointless to change the pistons and not the rods or not the rods and not the pistons. You can change both of them but that will also depend on how good your cylinder walls are as if you make too much power you will just push the walls out. Thats why JHM has to go through all the hassle of trying to put in cylinder wall support even with the sleeves
Now what do I do if the JHM tune doesn’t get rid of the CEL? I think I’ve seen one person still have a CEL after piggies and tune but I can’t seem to find that thread again.
Exactly. The JHM tune will help let the car know it should expect extra air flow for no cats but if you have a damaged or bad 02 it will give you a code. To say it differently if you have bad equiptment you will get a code if you just have a free flowing exhaust you wont have an issue
Oh okay thanks, I’m just trying to figure out if it ever happens when I get it done. It will be on the shop taking off my DP and putting them back on if they damage it to get a code?
SO I’m getting my piggies done tomorrow at a shop, whats the time I should expect for the removal of my DP and gutting and install again? Also, what should I expect when I get my car back besides a CEL? Increased power? Or does that only come after a tune?
I read that a lot haha but I’ve always thought i needed a tune for the car to learn what I did to it. I for sure am getting a 91 JHM tune in a few weeks not right after piggies so hopefully that will be okay but I plan to fill up 94 even with the 91 tune but have the 91 just in case because I know it will adapt. Whats the shop time for to get it done? I don’t wanna pay an outrageous time on it. My B7 is also auto so I know it will take longer than a manual S4
For someone to remove and gut the pre-cats, no more than an hour per pipe; entire job should be no more than 6hrs, at least three hours minimum. It shouldn’t take a qualified shop 6hrs to do…
I gutted my main and pre-cats in about two hours for both but that’s because I took my time then add in about 3hrs to reinstall/mount. I’m pretty anal/OCD about things so i generally double the time a shop can do things.
Awesome thanks! I saw a bunch of DIY and I woulda done it myself by taking them off would be the hard part, gutting looks hella easy. Hopefully this shop doesn’t take 6 hrs lol It took me 2 weeks to get in so they must be good… Their shop rate is $110/hr thats gnna be over 600 if it takes them 6hrs haha
I’ve got cracked downpipes causing a leak… Awesome… Now I have to either go aftermarket or find stock ones to gut them myself. Should I look at aftermarket options? Or stick with stock ones? I found a set local for $350 he said he took them off at 70,000Km so its still pretty new.
Idk how bad the crack is because the shop didn’t show me but what could be the cause of the cracked downpipes? Also, the DPs he has are manual and I have a tip so they won’t fit… It looks like I have to wait for a set of stock tip DPs and risk whatever happening with this crack OR order aftermarket ones right away. What after market ones are available thats relatively a good price thats also 2.5"?
JHM? Can’t justify 1200 US which comes out to like 1400 CDN for downpipes before shipping
Milltek? 860 was the cheapest I found for them before shipping as well.
Any other brands I’m missing that could work? I searched AZ but nothing.
