I finally had a chance to use my rosstech software last night to run a scan of my 08 S6. Ever since I’ve bought it, it starts poorly and doesn’t idle well until it warms up, now I’m getting a check engine light and a ESP warning on my dash. I can also smell gas when I start it and after driving it (haven’t’ really driven it much more than around the block for several months though - just moved and haven’t had time to work on it). These are the errors I’m getting that seem to be related to the issue (amongst other that I’ll have to work through after lol)
000135 - Fuel Rail/System Pressure P0087 - 002 - Too Low - MIL ON Freeze Frame:
Fault Status: 11100010
Fault Priority: 2
Fault Frequency: 7
Reset counter: 255
Mileage: 204235 km
Time Indication: 0
Date: 2007.05.17
Time: 05:59:36
Freeze Frame:
RPM: 2305 /min Load: 90.2 % Speed: 48.0 km/h
Temperature: 42.0°C Temperature: 20.0°C Absolute Pres.: 890.0 mbar Voltage: 13.589 V
P0087 - 008 - Too Low - Intermittent - MIL ON Freeze Frame:
Fault Status: 10101000
Fault Priority: 2
Fault Frequency: 4
Reset counter: 255
Mileage: 204291 km
Time Indication: 0
Date: 2022.06.19
Time: 18:59:21
Freeze Frame:
RPM: 2318 /min Load: 95.6 % Speed: 48.0 km/h
Temperature: 81.0°C Temperature: 24.0°C Absolute Pres.: 880.0 mbar Voltage: 13.716 V
008569 - Bank 2; System Too Lean off Idle
P2179 - 001 - - MIL ON Freeze Frame:
Fault Status: 11100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 204793 km
Time Indication: 0
Date: 2022.10.18
Time: 16:22:30
Freeze Frame:
RPM: 2208 /min Load: 52.1 % Speed: 15.0 km/h
Temperature: 96.0°C Temperature: 38.0°C Absolute Pres.: 900.0 mbar Voltage: 13.843 V
008567 - Bank 1; System Too Lean off Idle
P2177 - 001 - - MIL ON Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 204793 km
Time Indication: 0
Date: 2022.10.18
Time: 16:24:27
Freeze Frame:
RPM: 1676 /min Load: 48.2 % Speed: 77.0 km/h
Temperature: 98.0°C Temperature: 33.0°C Absolute Pres.: 890.0 mbar Voltage: 13.843 V
P1923 - 008 - Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 204821 km
Time Indication: 0
Date: 2023.02.06
Time: 20:55:29
Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h
Temperature: 7.0°C Temperature: 10.0°C Absolute Pres.: 880.0 mbar Voltage: 10.795 V
000772 - Cylinder 4
P0304 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 204350 km
Time Indication: 0
Date: 2022.06.22
Time: 06:07:46
Freeze Frame: RPM: 806 /min Load: 49.4 % Speed: 0.0 km/h
Temperature: 25.0°C Temperature: 19.0°C Absolute Pres.: 890.0 mbar Voltage: 14.097 V
004230 - Mixture Regulation; Bank 4; Range 2
P1086 - 001 - Lean Limit Exceeded - MIL ON Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 204734 km
Time Indication: 0
Date: 2022.10.17
Time: 20:28:17
RPM: 1489 /min Load: 43.5 % Speed: 67.0 km/h
Temperature: 81.0°C Temperature: 29.0°C Absolute Pres.: 900.0 mbar Voltage: 13.716 V
004226 - Mixture Regulation; Bank 3; Range 2
P1082 - 001 - Lean Limit Exceeded - MIL ON Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 204735 km
Time Indication: 0
Date: 2022.10.17
Time: 20:29:14
Freeze Frame:
RPM: 1635 /min Load: 40.8 % Speed: 75.0 km/h
Temperature: 92.0°C Temperature: 30.0°C Absolute Pres.: 900.0 mbar Voltage: 13.970 V
I’ve had the intake carbon cleaned and the injectors cleaned, only a few hundred km’s ago. Obviosuly I’m still having some sort of fuel issue. I don’t want to just start throwing parts at it if they’re not required especially since the HPFP’s are over $1000.00 CDN each around here. Does it look like this is the issue or is there possibly something else I should be looking at? Thanks.
