Power Steering Lines
I just finished putting a new engine into my 04 S4. The new (used) engine is from an 08 S4. Where the two hoses connect on the drivers side, right behind the coolant pump, I can’t remember which hose goes on top and which one goes on the bottom. I’m using the alldatadiy service, and unfortunately it’s not very in depth with the power steering.
From memory, I think the hose running from the reservoir goes on the bottom. The hoses look identical at the connections, and I don’t want to mix them up before I start the engine. Is this correct? Thanks!
Does this help?
http://audirevolution.net/addons/albums/images/837792558.gif
If your talking about the lines that go to the powersteering cooler thats on the front of the car. It dosent matter what line goes where if we are talking about the lines going to the cooler.
Thanks for the help! I did get the power steering fluid all filled up and working correctly.
Cheers!!
Great follow up nice to have you. WELCOME
