I just finished putting a new engine into my 04 S4. The new (used) engine is from an 08 S4. Where the two hoses connect on the drivers side, right behind the coolant pump, I can’t remember which hose goes on top and which one goes on the bottom. I’m using the alldatadiy service, and unfortunately it’s not very in depth with the power steering.
From memory, I think the hose running from the reservoir goes on the bottom. The hoses look identical at the connections, and I don’t want to mix them up before I start the engine. Is this correct? Thanks!
