PRNDS Lit up, Stuck in 3rd Gear
Hi,
I am new to this forum. Here is some background on my B7: my main problem on my 2008 Audi A4 2.0T (Tiptronic) was this:
049409 - No Communication with Transmission Control Module
U0101 - 008 - - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 65078 km
Time Indication: 0
I have replaced the engine harness, and now I can at least talk to the TCM (transmission control module). There was some water damage in the ECU box (mainly relays and wiring). PRNDS is all highlighted, and my tranny is in limp mode (3rd gear). Here is a copy of the full scan,
VCDS Version: Release 12.12.2 (x64)
Data version: 20140212
Friday,19,September,2014,18:14:11:46680
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUDF78E98A104241
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8E1 910 115 G HW: 8E0 907 115 D
Component: 2.0l R4/4V TFSI 0010
Revision: 5EH15— Serial number: XXXXXXXXXXXXXX
Coding: 0104010A020F0120
Shop #: WSC 06325 123 12345
VCID: 2643EC249151552EC1B-8073
No fault code found.
Readiness: 0110 0101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 8E1 910 156 K HW: 09L 927 156 B
Component: AG6 09L 2,0TFSI USA 0080
Revision: --H01— Serial number: 4386369
Coding: 0000002
Shop #: WSC 00000 000 00000
VCID: 2F6D0900BEAB146632D-807A
1 Fault Found:
001556 - Transmission Control Module
P0614 - 000 - Incorrect Software Version
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 13.0
Temperature: 25.0°C
T.B. Angle: 0.0°
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 J HW: 8E0 614 517 BH
Component: ESP8 quattro H06 0140
Coding: 0004528
Shop #: WSC 06325 000 00000
VCID: 2E531404B9A11D6E39B-807B
2 Faults Found:
01314 - Engine Control Module
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4722
Hex Value: 0x0014
Hex Value: 0x2195
Hex Value: 0x0001
18055 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 000 -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4722
Hex Value: 0x0014
Hex Value: 0x1096
Hex Value: 0x0001
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 M HW: 8E0 959 655 M
Component: Airbag 9.41 H01 4240
Revision: 91H01424 Serial number: 003CS0001CMZ
Coding: 0032607
VCID: 41895FB8183F9216D49-8014
Subsystem 1 - Part No: 8E0 910 339 D
Component: BF-Gewichtsens. H03 0080
Subsystem 2 - Serial number: 01K62
Subsystem 3 - Serial number: 0001.01.0000H0300000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332DRB4063645A4Lÿ†63
Subsystem 5 - Serial number: 645A4Lÿ†6342DRB40604CB13Lÿ†63
Subsystem 6 - Serial number: 4CB13Lÿ†6352ARB402F6B549Yÿ†63
Subsystem 7 - Serial number: 6B549Yÿ†6362ARB402F6B42D-ÿ†63
Subsystem 8 - Serial number: 6B42D-ÿ†63729RB403A0EF8F5ÿ†63
Subsystem 9 - Serial number: 0EF8F5ÿ†63829RB403A0EFBB5ÿ
Subsystem 10 - Serial number: 0EFBB5ÿ
End ---------------------------------------------------------------------
There were also another code that I cleared, but it might come back
002069 - Upshift Switch Circuit for Tiptronic (F189)
P0815 - 001 - Electrical Malfunction
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Any suggestions? Do I need to flash my TCM at the dealer?
-Matvey
