The spacers and crank pulley are a great combination. I’ll get to both of those soon. I did remove my SAI. I"m happy I did. For now removing it just helped take care of a few unneeded vac lines and some bulky hardware. With the JHM tune the SAI function is turned off so no harsh cold starts with crazy miss fires.
After my last post, I left off where my OEM intake was in need of repair or replacement. Since the JHM intake fix wasn’t ready at the time I paid the money and got a new one.
As some of you might know Audi came up with a new intake design to address the issues with the early intake manifold issues.
My intake already was the new updated part number. Little good that did, the new updated intake manifolds clearly didn’t fix the issue. Again I found something odd. The build date on my intake manifold was well before my actual car was built.
As if that little find wasn’t great the next thing I found was equally just as bad.
As you can see this intake was made about 6 months before I bought it. It came directly from Audi but as you can see it’s not actually new. As you can see from the marks and grime on the intake, this intake manifold is a repaired intake manifold. Still same part number as my original one but clearly not new.
This to me is a little frustrating. Here is why. You don’t really know your intake is messed up unless you pull it apart and after you do that it takes a good amount of work to put it back together. Since there are no actual sensors on the intake flaps you don’t know if one or more are broken. So, at this point, everyone could have a broken intake and unless you pulled it off and checked you wouldn’t know. As if that’s not bad enough the fixed or repaired intakes from Audi don’t appear to have anything different so, there is a very good chance that this intake will suffer the same fate as my other intake.
I do plan on taking apart this intake at the end of every season to check and see if it’s still holding up. So, that will at least be helpful and I’ll see if there is anything different on the inside of the intake vs my original one. I would have to say I don’t think there is going to be anything different. If Audi changes something they change the part number to reflect it.
oh well. Sucks about the intake but It’s not like that is going to stop me.
The next parts are the JHM intake spacers and the JHM crank pulley along with my SAI removal
Is the JHM intake fix ready now? I’m still driving without flaps at all, waiting for a solid solution. I might have to go back and find those old flaps to try the epoxy trick if something doesn’t happen soon.
Plus one, also Cv is the design itself flawed with opportunity to increase efficiency or power? Or is design good but longetivity is flawed?
Thanks for this post, basically becomes another maintenance check on these cars. Might make sense to create a new service manual of sorts to check on annually or every 18 months?
Let’s start getting to the good parts. The performance parts.
One of the best single parts you can put on the V10 motors. Is the JHM intake spacers. We all know the V10 heat is such a big deal. That heat is the single cause for numerous issues from pre-aging gaskets and other parts to robbing power and the overall drawbacks of just having too much heat.
The JHM spacers are a simple but well-proven part. These have been around and used not just by JHM but by actual race teams to do the same task. The spacers have been used for years in the Audi market to help drastically reduce heat and help return performance.
There are several things I like about the spacers. An additional thing I like on top of all the performance and other gains is that the JHM spacers actually work. They help seal the intake manifold from what I have seen. So, in my opinion, I see a better seal from the intake manifold to the heads as the JHM spacers make a nice fit and seal really well. This cuts down on the dreaded V10 misfire from intake leaks.
The only real note is to make sure to remove some of the motor pull assembly brackets when you install AND DO NOT REINSTALL THEM. If you try to reinstall the motor brackets you will get interference with the motor arm once the spacers are installed.
That was a great review. Great information that will really help. I did a review on the spacers for the 4.2 V8 and the 4.2 V8 runs cooler then the 5.2 V10
1/4" drive ratcheting wrench
M8 Triple Square/12 Point
M10 Triple Square/12 Point
14mm Wrench/Spanner
17mm Wrench/Spanner
Needle Nose Pliers
Flat Screwdriver
Extendable magnet
Give yourself about 2 hours.
following codes:
As I mentioned above. The JHM intake spacers made a huge impact on lowering the overall underhood temps along with giving better cooler intake temps.
Some of the exciting things I’ve done are
The JHM intake spacers - check we talked about those a few posts above.
Carbon clean - talked about that - http://audirevolution.net/forum/index.php?topic=4000.0
Up-date plugs and coil packs. - Did that earlier in the thread.
Compression test - Did this earlier in the thread.
Cylinder inspection - Did this earlier in the thread
Intake manifold inspection - Did this earlier in the thread
Coming soon…
The JHM Lightweight crank pulley - almost 9lbs of weight savings.
The JHM Lightweight brake rotors front and back - weight savings you wouldn’t believe
JHM beta ECU and TCU tune.
Full custom 3" exhaust
SAI removal - coming soon with the crank pulley
Fuel filter - part of the oil change and fluid assessment.
Oil change and fluid assessment.
After all, that I show the tract tested results from all the above work.
Since so many of us are opening their IM and reporting broken intake flaps (even with the updated part number) has anyone tried to convince Audi to make just the intake flap a replacement part instead of the entire IM? I would prefer that to hold me over until JHM comes out with an upgrade. (besides, I can’t seem to find the old flaps to do the epoxy mod)
It seems this is least Audi can do after leaving us with this whole carbon clean mess.
To be honest one would think if we got a consolidated document with the amount of broken IM and IM flappers with research and all signed and provided our invoice that Audi should warranty the part ever time installed for more than 12 months. This is similar to the driveshaft bushing that goes on just above every cayenne s and up trim levels. Porsche sells the entire driveshaft instead of the bushing only…so I paid 400 to upgrade from rubber to a very strong material which has been bullet proof for 400 dollars vs 1000+ for a new driveshaft and shitty rubber bushing. I think there was a a successful class action or at least traction on the cayenne issue driven by a few owners, I’m sure you could do the same here.
Remember there are probably only 4-7k of these cars left in NA inclusive of s6 and s8 so not sure how much attention Audi will give us. Now if you include world wide sales and convince those owners (should be easy minus language barriers) to participate you may be able to get somewhere
Your best bet is send a bunch of broken IM to JHM and see if they might be able to accelerate heir upgraded if that’s even on the table. Problem is the part works and does its job reasonably well. it just has too many points of failure and not durable enough. It becomes one of those things you check like carbon clean every year and a half or year if your anal like me
Yes, only catback. I really am fighting doing headers. I know it would wake the car up completely, but if I don’t go step by step we will never really know what mods do what. These few parts really wake the car up and the JHM tune is going to be the game changer that ties it all in.
I think Audi has moved on from the S6 and S8 motors enough were they wouldn’t even be able to help. At this point our best choice is going to be the aftermarket option.
Now back to the performance parts of the build. Last time we talked about the JHM intake spacers and their ability to help keep the 5.2 V10 heat issues in check. While the spacers are helpful at keeping the motor cooler and more efficient the motor could also benefit from shedding some of that unnecessary weight strapped to the front end of the crankshaft.
So what your saying is that I need that crank pulley for my S5!?
I was concerned that reducing the weight by so much is going to displace that force elsewhere…on some other rotating / moving part up or down the line. But what CV is saying that it is safe and in fact even better. Therefore that force/energy must being going to the wheels ;D!
You need a crank pulley for your S5. The stock crank pulley has a rubber diaphram inside that is there for hryomonic ballence. But due to the fact that the rubber diaphram is usually destryed on older crank pulleys people are not getting any use out of itanyways. That and in the V10 cars they have a huge fluid dampener on the car in the Tq converter so its kinda redundent. As for the S5 you have that huge flywheel that would absorb most of the vibration. The JHM crank pulleys are perfictly ballanced so you get no vibration from ballance issues.
