I got the chance to open up my spare manifold tonight and wanted to dispel a “theory” about the casting bolt coming loose and destroying the entire engine.
[QUOTE=mistral cytz;10055220]and remove all the bolts inside that are known to come loose and potentially drop in to a cylinder causing damage
If anything, Audi engineers do things for a reason; while it may not have DIY common sense value, their thought process is generally spot on.
Most of you know or have seen this so its nothing new but I performed an unscientific experiment with the bolts on the uppers/lowers:
Loosened one bolt up on the lower portion.
http://tapatalk.imageshack.com/v2/14/09/01/9130ef1df50f83a45bf44e0ac08196d4.jpg
Loosened up bolt on upper.
http://tapatalk.imageshack.com/v2/14/09/01/ffb8bfc2d28edf4b7d35f596be491d41.jpg
Sandwiched the top and bottom.
http://tapatalk.imageshack.com/v2/14/09/01/c0970cb309f6a8dd6e9f834580d141e4.jpg
The loosened bolts prevent the top from sitting properly to the bottom, creating a gap; no seal.
Experimented with one bolt screwed all the way in and one loose on last thread or two before:
Bolt screwed and hand-tightened all the way in to lower.
http://tapatalk.imageshack.com/v2/14/09/01/5374aab3b684581a4334f593cb48b8b5.jpg
Bolt sitting on one or two threads before falling out.
http://tapatalk.imageshack.com/v2/14/09/01/eb1538e0252b6f17826148994e6f9710.jpg
Again, theres a gap…even if the bottom bolt is fully seated, the top half of the manifold is not, therefore the gap.
http://tapatalk.imageshack.com/v2/14/09/01/ada198d9e935939d395f7f935679ef07.jpg
My conclusion, the likely hood of the bolt to “fall into” the engine bay is very unlikely ESPECIALLY if the manifold is bolted/sealed together; the loose bolts will block each other out and unless something happens will continue to sit in their threads.
