Ok, so I scanned the “Auto HVAC” for fault codes and this code came up. I then cleared it and it came back right away. Cleared it again, came back right away again.
Tuesday,07,March,2012,16:46:42:26365
VCDS Version: Release 805.1
Address 08: Auto HVAC
Control Module Part Number: 8E0 820 043 AM
Component and/or Version: A4 Klimaautomat 2831
Software Coding: 00000
Work Shop Code: WSC 00000
1 Fault Found
00819 - High Pressure Sensor (G65)
07-00 - Signal too Low
I also took a screenshot showing various parameters here: http://www.gauntlet.net/audi/ac_screenshot.jpg
The High Pressure sensor is at 11% and the range is 12% so that makes sense that it’s causing a fault code although I don’t know what it all means.
The compressor’s torque was 0 telling me it wasn’t running but that may because it was cold out. Not sure if that’s normal or not. I tried both setting the temp to LO as well as the defrost. I guess I’ll try again tomorrow when it’s warmer out.
Any thoughts?
