random miss or cough - but showing no codes......
Hey All,
pretty new issue, I had a rough running drive with lumpy idle so scanned her and came up with a
1 Fault Found:
000402 - Fuel Pressure Sensor (G247)
P0192 - 002 - Short to Ground - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 0
Fault Frequency: 11
Reset counter: 255
Mileage: 114644 km
Time Indication: 0
Date: 2018.10.22
Time: 11:57:48
I checked the loom to the pressure sensor I could get to (top of the motor on teh coolant res side) cleared the codes and she went fine.
Now every other drive it has a cough or miss. Normally a single event - with no MIL light or codes at all…completely clear. When it happens it feels like it pulls the cam timing and thus performance but unsure as there is no code to check this.
Any ways these cars can have a miss without recording anything? is this the way the crusty injectors show?
to repeat she stutters once (after its warm about 10min in) with nothing recorded.
