rear brake install required VAGCOM?
I’ve got F&R replacement rotors and pads and in searching for a shop to do the work I’ve gotten mixed answers. I’ve had shops tell me they can do the job but I want to be sure they can do so correctly. Is it correct that to push the rear calipers back in a VAGCOM is required to release the rear pistons? I don’t want someone blowing up my calipers in bench vice or with a C-clamp.
Thanks!
http://wiki.ross-tech.com/wiki/index.php/Working_on_the_Electro-Mechanical_Parking_Brake_(EPB)
http://store.ross-tech.com/shop/VCHUC.html
this is the one I assume
You need vcds or Carista to do the rear brakes. You can also use a 12v battery to retract the piston but it’s not the correct way to do it. Once the parking brake is retracted you use a c clamp to compress the cylinder back.
Might me a little late but check part of the way. down iits easy once you see it.
http://audirevolution.net/forum/index.php?topic=4192.0;topicseen
