Rear brake light/turn signal fault
I’ve been getting a sporadic fault from the right rear brake light & turn signal. It usually happens after a tropical rain. Tested the bulbs and they are still working—everything is fine the next morning.
Any suggestions?
Here is the scan from Carista:
Body/convenience system:
02743 - Right brake / turn signal lamp
Heater & air conditioning:
00797 - Sunlight Photo Sensor (G107)
Engine:
P1923 - Please Check DTC Memory of ECU Number 2
Engine (2):
P1573 - Left Eng. Mount Solenoid Valve, Open circuit
Radio:
00532 - Supply Voltage B+
00446 - Function Limitation due to Under-Voltage
