Rear subframe
If you loosen the rear subframe is there room to adjust or re-center the rear suspension or is it a fixed position?
I put on 10mm spacers on each side of the rear axle and now I am noticing that the passenger side rim is more flush with the fender than the driver’s side. I brought it to the dealership and had an alignment done but it doesn’t seem to have corrected things. It’s like the axle isn’t centered.
All 8E cars are like that when you lower them. It’s weird but totally normal and can’t be corrected.
Well damn. That is a bit disappointing. My symmetrical OCD compulsion is going crazy.
You shouldn’t be able to see both sides at once so either take down the mirrors on your garage, or drive the car (since you can’t see either side from the seat)
Haha, true enough.
