I am pulling my 2011 S5 3.0T CAKA engine, started out with replacing upper tensioners and from there found:
- Carbon build
- Oil filter caramel sludge bottom and metal sparkles on filter
- Spraying the sludge with brake cleaner, cleared te way for bigger aluminum chunks falling from drainage
- Draining coolant also metal shavings
- Leaking water pump
So I was done with the tight spaces, weird bolt angles and pulling it.
So when the engine is out, I have the possibility to change internals to upgraded ones. Google only found ECU tunes.
So any recommendations are gladly welcome!!
Those Supersprint Longtube Racing Header will not fit a 4.0T, lets follow this and see if he will sell them:see_no_evil:)
