Posted this over at Audizine but I thought I would get more visibility here. Hoping someone can give me some advice on a recent VCDS scan.
EDIT: I wanted to add that I did do the scan with aggressive mode enabled.
Hi all,
I have been reading on this forum about the mechatronics unit failures and decided to scan my 2014 RS5 to see if anything showed up. I have not seen any malfunction messages on the console nor have I noticed any shifting issues. After running the scan, I got a bit nervous as I saw the dreaded P0726 on the Auto Trans module. I also found there is a TSB from Audi on this but is says it is for MY 2013 and mine is a 2014 (build in June 2013). Hoping someone can take a look at the full scan and provide some advice.
Thanks in advance,
Andy
Tuesday,01,June,2021,04:31:42:39250
VCDS – Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WUAC6AFH8EN900172 License Plate:
Mileage: 74470km-46273mi Repair Order:
Chassis Type: FH-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 22 26 36 3C 42 44 46 47 52
53 56 5F 62 6C 72
VIN: WUAC6AFH8EN900172 Mileage: 74470km-46273miles
01-Engine – Status: OK 0000
02-Auto Trans – Status: Malfunction 0010
04-Steering Angle – Status: OK 0000
06-Seat Mem. Pass – Status: OK 0000
15-Airbags – Status: OK 0000
22-AWD – Status: OK 0000
26-Auto Roof – Status: OK 0000
36-Seat Mem. Drvr – Status: Malfunction 0010
3C-Lane Change – Status: OK 0000
44-Steering Assist – Status: OK 0000
46-Central Conv. – Status: OK 0000
56-Radio – Status: OK 0000
5F-Information Electr. – Status: Malfunction 0010
Address 01: Engine (------CFSA) Labels:. 079-907-560-CFS.clb
Part No SW: 8T2 907 560 F HW: 8T1 907 560
Component: 4.2l V8HDZ / H04 0005
Revision: NAH04—
Coding: 2225003225A6080D3000
Shop #: WSC 02789 002 1048576
ASAM Dataset: EV_ECM42FSI0118T2907560F 001004
ROD: EV_ECM42FSI011_AU48.rod
VCID: 3FDB485477F429D3B69-806A
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8T0 927 156 H HW: 0B5 927 156 J
Component: 0B5 42 FSINAR H02 0006
Revision: --H02—
Coding: 000001
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMDL501021 001025
ROD: EV_TCMDL501021.rod
VCID: 42DD41A00406443BD97-8016
1 Fault Found:
7980 - RPM Signal from ECU
P0726 00 [104] - Implausible Signal
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 74
Reset counter: 39
Mileage: 71928 km
Date: 2021.03.15
Time: 14:50:51
Engine RPM: 1098 /min
Transmission input speed: 1098 /min
Transmission output speed: 406 /min
Engine torque: 84 Nm
ATF temperature: 17 ∞C
Accelerator pedal position: 11.2 %
Clutch status: Kupplung 1 kann Moment ¸bertragen
Unlearning counter according OBD: 39
Transmission_rotational_speed_working_cycle-Data: 0 /min
Transmission input speed: 1098.00 /min
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8T0 907 379 F HW: 8T0 907 379 F
Component: ESP8 quattro H09 0100
Revision: -------- Serial number: --------------
Coding: 341D1A
VCID: 45D75ABC15A87303FC5-8010
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 GP HW: 8K0 907 064 FP
Component: BCM2 2.0 H12 0633
Revision: 00002001
Coding: 0D834040000000000000
VCID: 045187B85E128A0BABB-8050
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Component: J764 ELV MLB H40 0046
Serial number: 2313000106921005
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 F HW: 8T0 959 760 F
Component: MEM-BFS H10 0076
Revision: AA000000 Serial number: 00000062251600
Coding: C80370250D2400001000
VCID: 46D55DB028AE781BF5F-8012
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 AL HW: 8K1 820 043 AL
Component: KLIMA 3 ZONEN H04 0121
Revision: C3000000 Serial number: 01120620130644
Coding: 4803200E00
VCID: 72BDD16074A6B4BB897-8026
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00000627536001
Coding: 06000091043CAFE0250048C0000039094F9CD388A209022100 000B004000010200040074000000
VCID: 7AADF9402CD6CCFBC17-802E
Subsystem 1 - Part No SW: 8F1 955 119 HW: 8K1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 110613 H07 0080
Serial number: SWF13060115327
Coding: 00FD11
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 21422127
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AQ HW: 8K0 941 531 AQ
Component: E1 - LDS H03 0031
Serial number: 00000000002705130094
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 0000002274555R6ELW02
Subsystem 5 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 6 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 1428C1B6000000000001
Address 15: Airbags (J234) Labels:| 8F0-959-655.clb
Part No SW: 8F0 959 655 E HW: 8F0 959 655 E
Component: AirbagVW-AU10 H12 0430
Serial number: 003KKD808MX+
Coding: 303741353731303030304A55304C38463053
ASAM Dataset: EV_AirbaAU10SMEAU485 001004
ROD: EV_AirbaECUVWAUDI010.rod
VCID: 3A2D39406CD60CFB817-806E
Seat occupied recognition:
Subsystem 1 - Part No SW: 8K0 959 339 A HW: 8K0 959 339 A
Component: BF-Gewichtss. H02 0060
Serial number: 5810000R130000DQXT
Crash sensor for side airbag: driver side:
Serial number: 6334MSME7954614EN
Front Passenger’s Side Airbag Crash Sensor:
Serial number: 6344MSME7B242D2BQ
Rear Side Airbag Crash Sensor (on driver’s side):
Serial number: 6352QSME11324B7EK
Passenger side rear thorax airbag crash sensor:
Serial number: 6362QSME073219404
Crash sensor for front airbag: driver side:
Serial number: 63732SME3934585C5
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME39342C7A7
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372MEN000M8
Coding: 000036
VCID: 44D147B81E924A0BEBB-8010
Component: E221 - MFL H03 0004
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8T0 920 984 H HW: 8T0 920 984 H
Component: KOMBIINSTR. H35 0563
Revision: 00500000 Serial number: WVZ35996E
Coding: 8BBF19008B01D705020000
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0056
Revision: 1Z110028 Serial number: 2841Z13529014E
Coding: 80E3031600
VCID: 4CC16F9836C2824B23B-8018
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 0779180603
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
Component: 4 Wheel Drive H14 0100
Serial number: 001506130001413
ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
ROD: EV_AllWheelDiffeQSPCAN.rod
VCID: 2F3B1814A794D953269-807A
Address 26: Auto Roof (J256) Labels:* 8F0-959-255.clb
Part No SW: 8F0 959 255 HW: 8F0 959 255
Component: VSG-AUDI-B8 H12 0190
Coding: 030000
ASAM Dataset: EV_ElectRoofContr 001008
ROD: EV_ElectRoofContr.rod
VCID: 71BFDE6C71208FA370D-8024
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Component: MEM-FS H10 0076
Revision: AA000000 Serial number: 00000062251817
Coding: C81B7B250D2400001000
1 Fault Found:
00447 - Function Limitation due to Over-Voltage
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 39
Reset counter: 157
Mileage: 70110 km
Time Indication: 0
Date: 2020.12.27
Time: 17:25:46
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H04 0060
Serial number: 0306692379
Coding: 010211
ASAM Dataset: EV_LaneChangAssis 001020
ROD: EV_LaneChangAssis_AU21.rod
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H04 0060
Serial number: 0305822649
Coding: 000102
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0305
Coding: 011C53724E08332C03
VCID: 56F58DF0F80EC89B85F-8002
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0010572409
Coding: 100000010001
ASAM Dataset: EV_RCEPSAU48X 008014
ROD: EV_RCEPSAU48X_008.rod
VCID: 343117784EB2FA8B5BB-8060
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0309031354
Coding: 010602BA00FA402180B0033200000000
Subsystem 1 - Part No SW: 8F0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000677792
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8F1 035 223 A HW: 8F1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94833015988702
VCID: 1F1BE8D4D7B449D3969-804A
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0305
Coding: 011C53324E08332C03
VCID: 55F78AFCE508C3838C5-8000
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 M HW: 8K0 907 801 J
Component: EPB-4 H01 0004
Revision: -------- Serial number: 00000001323561
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_AU48.rod
VCID: 392F264C69D007E388D-806C
Address 56: Radio ® Labels: Redir Fail!
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H60 0133
Revision: AB001007 Serial number: 156F-0D7814810
Coding: 020007010000000101
VCID: 2411E738FED26A0BCBB-8070
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 8R1 035 746 D HW: 8R1 035 746 D
Component: H-BNT-NA H40 0738
Revision: -------- Serial number: 204F.0D7583517
Coding: 150200030306E1EF55028B4E00000401150000000000000000
VCID: 38292348525A1EEB773-806C
Subsystem 1 - Part No: 8R0 060 884 BD
Component: NAR 2013/2014 0802
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130EP0D2745333
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Component: E0380 Bedient H02 0030
Serial number: 00000001533139
Subsystem 4 - Part No: 8R0 060 961 F
Component: CD-Database 5298
3 Faults Found:
00658 - Control Head
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 30
Reset counter: 143
Time Indication: 15
Freeze Frame:
Voltage: 12.20 V
02244 - Button in Control Head is Stuck
Freeze Frame:
Fault Priority: 5
Fault Frequency: 26
Reset counter: 159
Mileage: 73593 km
Time Indication: 0
Date: 2021.05.13
Time: 18:33:27
Freeze Frame:
Voltage: 13.20 V
Hex Value: 0x0005
not available
03389 - Data Set Implausible
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 228
Mileage: 70538 km
Time Indication: 0
Date: 2021.01.11
Time: 19:01:04
Freeze Frame:
Voltage: 11.40 V
Bin. Bits: 010
Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
Part No SW: 8T0 959 795 F HW: 8T0 959 795 F
Component: TSG HL H08 0305
Coding: 010C13304008372C03
VCID: 4EC56590C0DEB05B4DF-801A
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8F0 907 441 HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H08— Serial number: 525PA8-J35B0DJ
Coding: 1020009
VCID: 678BB034436441132E9-8032
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Component: TSG HR H08 0305
End----(Elapsed Time: 02:04, VBatt start/end: 11.6V/11.7V. VIgn 11.7V)-----
