I have my car apart doing a carbon clean (+coils, plugs, oil, etc). decided to do injector cleaning at the same time. Any recommendation on a place that does RS4 injectors?
From what my research has shown as I’ve been heavly looking into the V10 FSI motors and they are plagued with injector issues. The only company that tests cleans and flows these FSI injectors past 5bar and keep in mind 5 bar is idle on FSI cars is JHM. JHM tests the injectors up past 1500psi that is unheard of with everyother company out there that does this.
The higher PSI shows where injectors leak where the lower 5bar leaves out the ability to show injectors leaking at the higher 8bar of part throttle driving.
JHM has a core charge system so they might have a set of injectors sitting there so you can just send in and swap out your old ones.
