Hi, I have had an issue with a couple of injector locations since owning the car. I say locations because I keep replacing the injectors, all will be ok for a bunch of months then after a long while I’ll feel some stumbling, scan the car and voila fucking injector code in the same location.
As above the symptoms are usually some light stumbling. I know it’s the physical injector that eventually goes bad because I have moved them around after getting a code on a cylinder and the code will move to the new injector location.
The weird part is it has been almost always on cylinder 4. So what could be going on that would cause injectors in that location to periodically shit the bed?
So far it hasn’t been a big deal though if I could stop buying injectors once or so a year I wouldn’t be upset (never mind I’ve gotten a nice face full of gas once when changing them out).
Thoughts?
