Replacement Headlight Options
Hello.
I am very close to purchasing a 2008 Audi S6. It does have the common Adaptive Headlight errors. The dealer I am purchasing the car from was able to fix one of the headlights (broken wire) but the other is not repairable. They are trying to source a used replacement but have not found any yet.
While it would be nice to have the adaptive headlights working, it isn’t too big of a deal if I don’t have them.
So are there any good aftermarket replacement headlight? Also, can the adaptive headlight error be coded out if I go that route?
Thanks.
There’s plenty of reasonably affordable Audi S6 C6 headlights. As far as after market goes, I don’t believe there are any. The only replacement to the Audi S6 headlights would be RS6 headlights - not necessarily the most inexpensive option. However, there are after market tail lights that are upgraded LEDs and look nice.
When you say “reasonably affordable Audi S6 C6 headlights” do you mean the used one’s on ebay?
On eBay you’ll find both new and used if I can recall correctly. You made need to “relocate” yourself under Germany to explore more options. Likewise, carparts.com should have some used headlights at decent prices.
I found a set of relatively cheap headlights from a 2007 S6. Hopefully, they work or if not they will be easy to repair. Thanks.
