Exactly its pretty straight forward but If I was to just post walk though what I remember
1 make sure to disconnect the PCV connections on the back of the passenger side inlet just before the throttle body. They are finickey but they are push clips. Take your time and take those out first. You might need to remove the driver side intake tube from the throttle body and air box to get the most room.
2 make sure to do the same on the driver side but there isn’t any PCV connections on the driver side air inlet so just remove.
3 from there you will need to unplug the MAF sensor on both sides. Make sure to set that out of the way but try to place it up top and zip tie it out of the way.
4 Each air box should have 4 or 5 screws that hold the tops on. Take your time and make sure to find all of them. Loosen them and back them out all they way. They are held into the air box top so you might not be able to actually removed them…
5 after that take your time and on the I think passenger side look into the top portion of the air box. The SAI pipe pumps air into that side so you have to be careful and unhook that when you pull the air box top off.
6 once you have the driver or passenger side air box top off make sure to place a piece of duct tape on the driver side air box top if you don’t do them one at a time do the same with the MAF units. Even tho you have the SAI connection on the one side it can be easy to mix up the air box maf filter and air box tops if your not careful
7 at this point you should be able to see what needs to be done and its straight forward.
Keep in mind this is just from memory.
