Hi super.
Here are a few too late for the project but perhaps helpful tips.
When doing the air filter service, try to do this after a longer drive or when the engine bay is warm.
Having warm hoses tends to help reduce breakage and usually ends with better results, less fighting with the clips.
It is also a good time to remove and inspect the plastic lines and inspect them. Many times there will be small cracks that can cause bigger issues down the line. Such things as misfires and fuel related codes.
As for changing the filters. You don’t need to change the filters every oil change but definitely inspect them and the air boxes for debris. If the air filters look in poor condition then I would always bias on the side of replacement.
When it comes to cleaning the K&N filters. I would follow their instructions. But to give a quick run down. You can take them and clean them with soap and water. Light soap and water. It’s important to remember that the filter material on K&N filters lets a large amount of air pass by them, this is what helps the motor breath better.
It’s the oil itself that aids in making the filters perform better in the filtration department. Do don’t be shy with the oil but then again don’t over do it. We have mas air meters on our cars and they don’t like oil on them.
What I do is, clean the filters until I don’t see any more red oil on them. Let the filters dry over night and then add K&N oil back over the filters until the red color comes back to the filter. I wait for the oil to set in and then add more as needed.
