My rad sprang a leak a few weeks ago, so I’m in the process of removing it. I have it pretty much ready to remove - just need to drain it and remove the hoses now. While I have it apart I plan on fixing a few other things, I’ve gotten a:
001152 - Coolant Fan Control Circuit 1
P0480 - 002 - Electrical Malfunction
Ever since I first scanned the car, the fan works but it does seem to run too often and can cause it to take a long time to warm up when it’s cold. Is that circuit part of the fan or is it a separate module? I can’t find any info on it.
Just curious what people are using to refill - the few times I’ve had to top up I’ve used pentofrost sf but it’s not cheap, is there a better option?
Also, when I’m putting it back together is there a recommended method for bleeding air out? Any help would be appreciated
Thanks in advance
oh well, I’ll deal with that later. And fyi for anyone thinking of using the jhm lightweight crank pulley, I’ve put a couple hundred km’s on it so far and no issues with the belt slipping off (knock on wood), you can definitely feel the difference. The engine revs up much quicker, especially at higher rpms.
