Thank you for the reminder @justincredible; that’s my bad. I attached the scans to this reply. I think the first scan was one system and the second is an all systems scan. Thank you.
Saturday,19,February,2022,17:29:38:25692
VCDS – Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: WAUGN94F37N089902 License Plate:
VCDS Release 21.9.0: SRI Reset
Control Module Part Number: 4F0 910 930 C Labels: 4F0-910-xxx-17.lbl
Component:KOMBIINSTR. M73 H18 0120, Coding:2129268
Operation: Please select an operation
Channel Description Unit Current val. New val.
02 Service Reminder Status 1 —
40 Mileage since Service miles x100 101 —
41 Time since Service Days 380 —
42 Min Mileage to Service miles x100 100 —
43 Max Mileage to Service miles x100 100 —
44 Max Time to Service Days 365 —
45 Oil Quality 1 —
47 Soot Quantity km x100 0 —
48 Thermal Load km x100 47 —
49 Min Time to Service Days 365 —
Saturday,19,February,2022,17:33:00:25692
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Control Module Part Number: 4F0 910 273 B HW: 4F0 907 273 A
Component and/or Version: Reifendruck 3 H05 0100
Software Coding: 0062725
Work Shop Code: WSC 02335 785 00200
VCID: 221DE5CF48C9B4DB915-8076
1 Fault Found:
01521 - Sensor for Tire Pressure
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 115
Reset counter: 167
Mileage: 159020 km
Time Indication: 0
Date: 2019.01.27
Time: 16:08:44
Freeze Frame:
(no units): 30.0
Voltage: 13.80 V
(no units): 61.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Friday,01,July,2022,16:03:03:25692
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
Data version: 20220407 DS337.0
Address 01: Engine (4F1 910 552 A)
16:03:00 Group 001: General
0 /min Engine Speed (G28)
93.0°C Coolant Temperature (G62)
0.0 % Lambda Control Bank 1/2
0.0 % Lambda Control Bank 3/4
Wednesday,16,November,2022,21:13:25:25692
VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4
Data version: 20221026 DS344.0
Address 11: Engine II (4F1 910 552 A)
21:13:22
-7.0 % Lambda Control Bank 1/2
-10.5 % Lambda Control Bank 3/4
0 Misfire Counter
Enabled Misfire Recognition
0 Misfire Counter Cylinder 1
0 Misfire Counter Cylinder 2
0 Misfire Counter Cylinder 3
0 Misfire Counter Cylinder 4
0 Misfire Counter Cylinder 5
34.80 bar Fuel Rail Pressure (actual)
0.00 bar Fuel Rail Pressure (spec.)
3 Fuel Pressure Control Status
Monday,21,November,2022,12:43:24:25692
12:43:22 Group 031: Lambda Control (Lambda Sensor Voltages)
0.99 Lambda Control Bank 3 (actual)
1.00 Lambda Control Bank 3 (specified)
1.00 Lambda Control Bank 4 (actual)
1.00 Lambda Control Bank 4 (specified)
12:43:22 Group 032: Lambda Control (Mixture Adaptation)
-0.4 % Adaptation (Idle) Bank 3 Sensor 1
-4.7 % Adaptation (Partial) Bank 3 Sensor 1
-0.1 % Adaptation (Idle) Bank 4 Sensor 1
-3.1 % Adaptation (Partial) Bank 4 Sensor 1
Monday,21,November,2022,12:52:28:25692
12:52:20
-2.7 % Lambda Control Bank 1/2
2.3 % Lambda Control Bank 3/4
15.8 % Engine Load
0 Misfire Counter
0.0 % Adaptation (Idle) Bank 4 Sensor 1
-2.7 % Adaptation (Partial) Bank 4 Sensor 1
34.20 bar Fuel Rail Pressure (spec.)
34.99 bar Fuel Rail Pressure (actual)
Saturday,21,January,2023,11:40:28:25692
11:40:24
1 Misfire Counter
1 Misfire Counter Cylinder 2
0 Misfire Counter Cylinder 6
0 Misfire Counter Cylinder 7
0 Misfire Counter Cylinder 8
0 Misfire Counter Cylinder 9
0 Misfire Counter Cylinder 10
Saturday,21,January,2023,14:38:06:25692
Address 01: Engine Labels: 07L-910-552-BSM1.clb
Control Module Part Number: 4F1 910 552 A HW: 4F1 907 552
Component and/or Version: 5.2L V10/4V FSI ª0040
Software Coding: 01050009190F0160
Work Shop Code: WSC 66565 257 00032
VCID: 221DE5CF48C9B4DBDD6-8076
1 Fault Found:
008567 - Bank 1; System Too Lean off Idle
P2177 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 173137 km
Time Indication: 0
Date: 2022.11.10
Time: 14:21:34
Freeze Frame:
RPM: 1674 /min
Load: 37.2 %
Speed: 34.0 km/h
Temperature: 91.0°C
Temperature: 21.0°C
Absolute Pres.: 950.0 mbar
Voltage: 13.843 V
Readiness: 0000 0000
Sunday,18,June,2023,14:46:40:25692
VCDS Version: 23.3.1.0 (x64) HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
Address 01: Engine ()
14:46:17
N/A Engine Speed (G28)
N/A Mass Air Flow Sensor (G70)
N/A Idle Regulator
N/A Idle Stabilization Self-Adaptation
11.7 % Throttle Valve Sensor 1 (G187)
88.3 % Throttle Valve Sensor 2 (G188)
1.2 % Throttle Valve Actuation
9 Fuel Pressure Regulator
30.92 bar Fuel Rail Pressure (actual)
30.18 bar Fuel Rail Pressure (spec.)
-0.34 bar Fuel Rail Pressure (actual)
Wednesday,21,June,2023,18:32:30:25692
VCID: 221DE5CF48C9B4DA39F-8076
1 Fault Found:
000402 - Fuel Pressure Sensor (G247)
P0192 - 002 - Short to GND - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 175082 km
Time Indication: 0
Freeze Frame:
RPM: 267 /min
Load: 31.8 %
Speed: 0.0 km/h
Temperature: 60.0°C
Temperature: 24.0°C
Absolute Pres.: 920.0 mbar
Voltage: 12.065 V
Blockquote
Wednesday,21,June,2023,18:30:16:25692
www.Ross-Tech.com
VIN: WAUGN94F37N089902 License Plate: TODAY
Mileage: 175120km-108814mi Repair Order:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 11 31 15 16 17 19 1E 36 37 42 46
47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUGN94F37N089902 Mileage: 175120km-108814miles
07-Control Head – Status: OK 0000
08-Auto HVAC – Status: Malfunction 0010
0F-Digital Radio – Status: Malfunction 0010
11-Engine II – Status: OK 0000
31-Engine other – Status: OK 0000
15-Airbags – Status: OK 0000
1E-Media Player 2 – Status: OK 0000
36-Seat Mem. Drvr – Status: Malfunction 0010
55-Headlight Range – Status: OK 0000
56-Radio – Status: OK 0000
61-Battery Regul. – Status: Malfunction 0010
65-Tire Pressure – Status: Malfunction 0010
76-Park Assist – Status: OK 0000
Address 01: Engine Labels:. 07L-910-552-BSM1.clb
Part No SW: 4F1 910 552 A HW: 4F1 907 552
Component: 5.2L V10/4V FSI ª0040
Revision: 59H09— Serial number:
Shop #: WSC 66565 257 00032
VINID: 9D19577891160C7780209240083D7A087A
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 175082 km
Time Indication: 0
Freeze Frame:
RPM: 267 /min
Load: 31.8 %
Speed: 0.0 km/h
Temperature: 60.0°C
Temperature: 24.0°C
Voltage: 12.065 V
Part No SW: 4F2 910 156 M HW: 09E 927 156 C
Component: AG6 09E 5,2 FSI USA 0070
Revision: --H01— Serial number: 0096786
Coding: 0000002
Shop #: WSC 22705 444 89150
VCID: 2F3B1CFB0B1B09B2A61-807A
No fault code found.
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0115121
Shop #: WSC 22705 444 53973
VCID: 30391F871625164ABFB-8064
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 22705
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 22705
Address 11: Engine II Labels:. 07L-910-552-BSM2.clb
Shop #: WSC 91520 999 69871
Address 61: Battery Regul. Labels: 4F0-910-181.clb
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000152346
Shop #: WSC 22302 444 85830
VCID: 2313E0CB57D3BDD2329-8076
Subsystem 1 - Part No: 000 915 05D L
Component: von VA0 310708820C
Coding: 3030303931353035444C2056413033313037303838323043
Shop #: WSC 00000 384 00290
2 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 170107 km
Time Indication: 0
Date: 2022.06.17
Time: 13:38:43
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 170107 km
Time Indication: 0
Date: 2022.06.17
Time: 13:42:09
End----------(Elapsed Time: 02:11, VBatt start/end: 12.1V/12.1V)-----------
