Yesterday was a little confusing, at least for me. However, I think I’ve got some tangible evidence. I walked out of the shop and forgot the dyno print outs but, to be honest, they were somewhat ambiguous. The first run ,with APR and meth injection off, showed a max of 328HP, at third gear and then again at the fourth gear pull with the max 6200 rpm. The second pull, meth injection on, showed the same peak HP but revealed that between 3600 RPM and about 4300 RPM the meth increased HP by about 20 horses. The dyno bay had a small weather station in it. We started at about 11AM. The temp was 84.6F, barometer 30.06, and humidity of 42%. The car was then allowed to cool for a couple of hours and the REVO ECU and DSG tunes were installed. Now it get confusing. Since the car can now spin to 7000 RPM in fourth gear it reaches 125 mph on the dyno, fourth gear, at about 6500 RPM and the dyno shuts down at that speed. The best we saw at 6500 RPM was only about 5-10 more HP. However, when we did a third gear pull, meth on, we saw 351 HP at 7000 RPM compared to the APR pull, meth on, of 328HP. This all occurred at about 2 PM, temp had increased to 87.3F, Baro had dropped to 29.97 and humidity was down to 40%.
Not the best of testing but I did my best…it was an expensive dyno day. Of course once the APR flash was gone we could not go back. The tech told me it would take about 20-30 miles for the ECU to adapt. The ride home was about 60 miles. Car feels strong but on way home saw 89F on the car thermometer so any subjective judging is meaningless. The good news is I can now spin to 7000 RPM like the big boys…finally. When in manual one must change gears manually. Down in auto remains normal and up shifting, again in auto, occurs at 7000 rpm.
I did my best, the quarter mile will be the best testing grounds. It appears it will be about 3 weeks before I can do just that. Below is a list of engine options currently on car. I hope this help!?!?
Roc Euro intake
APR CPS
Euro Code headers
Miltek resonated exhaust
Aquamist HSF 4 meth injection running pure meth.
which is why it’s important to Rev out as much as you can when running the 1/4 mile. Is also the reason you weren’t impressed in the past with times or dyno…You were shutting down at a mere 6.5k rpm.
