Revolv0’s Salvage Rescue S6
Hey Lake,
After some extensive testing, the transmission problem is as follows:
When taking off from a dead stop in first gear, AND the trans is cold: I get a that delayed, neutral rev, followed by first gear engagement. Trying out different throttle engagements just made the “snap” into gear more harsh or gentle.
When driving the car at full operational temp, first gear works flawlessly. Downshifts from second, at various RPM’s works great, and from a dead stop is perfect. It pulls HARD from first when warm, and shifts into second quickly.
Thoughts? I am thinking another fluid flush is in order to prove out your experience with the Toureg.
SB
I know it’s probably a dumb question, but when you dealt with the fluid, did you follow the instructions about temperature and proper level indication?
Ed
Ed, definitely a good question:
His comment was “Yes around 35-40 C” to top off.
He (thankfully) made an error and confused my car with a guy that had a bad DSG. The clutch pack comment was not for me. Phew.
“The original fluid did not seem burnt that I took out, so I am suprised to hear its engaging poorly. Low preassure is the leading cause to this soft of engagement, generally a fluid level problem, or a burnt holding band, both of which I think we can rule out in your case…”
and
" The fluid definitely is not low, i measured the amount that came out when draining and compaared it to the amount i put back in. It actually took slightly more than came out…"
Yeah but the information I gathered to do mine says nothing about measuring. It talks about dripping and temperature and running the gear selector as you fill and most importantly not letting the transmission getting above a certain temperature.
The Bentley also recommends running an adaptation after changing fluid.
While I know how to add images, I do not know how to attach files like word docs and spreadsheets, otherwise I would attach what I used.
Ed
Small Update 93000 miles.
Ordered and (just) installed adam rotors, with new pads, stainless steel lines, and brake fluid flush. I’ll post some pics soon. Didnt even do the brake in period yet on the rotors/pads.
Update from the Christmas carbon cleaning / plug replacement / Coil pack replacement at 101500 miles…
When taking off the JHM intake manifold, I may have tweeked one of the intake runner arms (i felt a ‘click’ on the left arm when working the intake off). Note to future members, dont mess with the arms with taking off, putting on the intake!
Performed the carbon cleaning installed another set of NGK 5592 plugs, installed the BREMI coil packs (original were dated in 07, so it was time).
Started the car back up, cleared the codes in VCDS and got the following codes: P2014 and misfires out the ass. Note, the car runs, idles, drives like shit. The misfiring is concerning. I looked at blackwidows intake code post, and the sock ordeal for some insight. I plan to take the intake off, should it just be a matter or replacing the intake position sensor for bank 1? If so, part number? Bank 1 should be number one in the picture below?
VIN: WAUGN94F67N150224 Mileage: 165920km-103097miles
00-Steering Angle Sensor – Status: OK 0000
01-Engine – Status: Malfunction 0010
02-Auto Trans – Status: OK 0000
03-ABS Brakes – Status: OK 0000
05-Acc/Start Auth. – Status: Malfunction 0010
07-Control Head – Status: Malfunction 0010
08-Auto HVAC – Status: OK 0000
09-Cent. Elect. – Status: Malfunction 0010
0E-Media Player 1 – Status: OK 0000
0F-Digital Radio – Status: Malfunction 0010
11-Engine II – Status: Malfunction 0010
31-Engine other – Status: Malfunction 0010
15-Airbags – Status: Malfunction 0010
16-Steering wheel – Status: OK 0000
17-Instruments – Status: OK 0000
19-CAN Gateway – Status: Malfunction 0010
1E-Media Player 2 – Status: Malfunction 0010
36-Seat Mem. Drvr – Status: OK 0000
37-Navigation – Status: OK 0000
42-Door Elect, Driver – Status: OK 0000
46-Central Conv. – Status: Malfunction 0010
47-Sound System – Status: OK 0000
4F-Centr. Electr. II – Status: OK 0000
52-Door Elect, Pass. – Status: OK 0000
53-Parking Brake – Status: OK 0000
55-Headlight Range – Status: OK 0000
56-Radio – Status: OK 0000
61-Battery Regul. – Status: Malfunction 0010
62-Door, Rear Left – Status: OK 0000
67-Voice Control – Status: OK 0000
6C-Back-up Cam. – Status: OK 0000
72-Door, Rear Right – Status: OK 0000
76-Park Assist – Status: OK 0000
77-Telephone – Status: OK 0000
Address 01: Engine Labels:. User\07L-910-552-BSM1.lbl
Part No SW: 4F1 910 552 A HW: 4F1 907 552
Component: 5.2L JHM/V1 OCT9 ª0040
Revision: 59H14— Serial number:
Coding: 01050009190F0160
Shop #: WSC 02335 758 00200
VCID: 221DEFE058CF1A3B456-8076
2 Faults Found:
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 165926 km
Time Indication: 0
Date: 2021.02.03
Time: 18:10:21
         Freeze Frame:
                RPM: 650 /min
                Load: 16.1 %
                Speed: 0.0 km/h
                Temperature: 98.0°C
                Temperature: 55.0°C
                Absolute Pres.: 980.0 mbar
                Voltage: 13.970 V
008212 - Intake Manifold Flap Position Sensor (Bank 1)
P2014 - 002 - Electrical Malfunction
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 165926 km
Time Indication: 0
Date: 2021.02.03
Time: 18:10:21
         Freeze Frame:
                RPM: 325 /min
                Load: 30.6 %
                Speed: 0.0 km/h
                Temperature: 98.0°C
                Temperature: 55.0°C
                Voltage: 12.446 V
Readiness: 0110 0101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4F2 910 156 M HW: 09E 927 156 C
Component: AG6 09E 5,2 FSI USA 0030
Revision: --H01— Serial number: 0104372
Coding: 0000002
Shop #: WSC 13622 410 403014
VCID: 2F3B16D41B1DA753DA8-807A
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 P HW: 4F0 614 517 P
Component: ESP 8.0 quattro H05 0070
Revision: 00000000 Serial number: 00000000000000
Coding: 0020920
Shop #: WSC 02325 758 00200
VCID: 313F10AC0D29B1A3CCC-8064
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 A HW: 4F0 905 852 C
Component: FBSAUDIC6 ELVSG H01 0030
Revision: 31050601 Serial number: 10601200717004
Coding: 0000007
Shop #: WSC 05194 003 1048576
VCID: 2411E9F842DB140B37A-8070
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0053
1 Fault Found:
00955 - Key 1
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01110010
Fault Priority: 3
Fault Frequency: 5
Reset counter: 210
Mileage: 159915 km
Time Indication: 0
Date: 2020.11.19
Time: 07:10:02
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 R HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 361CI077513226
Coding: 0010003
Shop #: WSC 02334 758 00200
VCID: 323D1FA0082F8ABBB56-8066
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000000722774
Subsystem 3 - Serial number: 0104.04.070000000100010914ÿ
Subsystem 4 - Serial number: 010914ÿ
2 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 205
Mileage: 119165 km
Time Indication: 0
Date: 2019.10.02
Time: 19:49:53
01964 - Control Module for Seat & Steering Column Memory (J136)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 218
Mileage: 163513 km
Time Indication: 0
Date: 2021.01.12
Time: 12:06:24
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000052 Serial number: 00000030227633
Coding: 0524330
VCID: 1C61D1187AAB2CCB8FA-8048
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0115123
VCID: 303915A80623B8ABC32-8064
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 02335
1 Fault Found:
01494 - Bulb for Parking Lamps; Left (M1)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 249
Mileage: 165700 km
Time Indication: 0
Date: 2021.01.30
Time: 07:55:00
Address 0E: Media Player 1 (R192) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 HW: 4E0 035 785
Component: SG ext.Player H09 0170
Revision: 00000000
VCID: 6597B4FC05612D03E04-8030
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 H HW: 4E0 035 593 D
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7G0071800
Shop #: WSC 00000 000 00000
VCID: 2C0101D82A0BDC4BFFA-8078
Address 11: Engine II Labels:. User\07L-910-552-BSM2.lbl
9 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 -
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 165926 km
Time Indication: 0
Date: 2021.02.03
Time: 17:54:56
         Freeze Frame:
                RPM: 629 /min
                Load: 20.0 %
                Speed: 0.0 km/h
                Temperature: 89.0°C
                Temperature: 24.0°C
                Voltage: 13.843 V
000774 - Cylinder 6
P0306 - 001 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 165926 km
Time Indication: 0
Date: 2021.02.03
Time: 17:54:56
         Freeze Frame:
                RPM: 629 /min
                Load: 20.0 %
                Speed: 0.0 km/h
                Temperature: 89.0°C
                Temperature: 24.0°C
                Voltage: 13.843 V
000784 - Cylinder 10
P0310 - 001 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 165926 km
Time Indication: 0
Date: 2021.02.03
Time: 17:54:58
         Freeze Frame:
                RPM: 642 /min
                Load: 20.0 %
                Speed: 0.0 km/h
                Temperature: 88.0°C
                Temperature: 24.0°C
                Voltage: 13.970 V
000775 - Cylinder 7
P0307 - 001 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 165926 km
Time Indication: 0
Date: 2021.02.03
Time: 17:55:28
         Freeze Frame:
                RPM: 645 /min
                Load: 20.8 %
                Speed: 0.0 km/h
                Temperature: 87.0°C
                Temperature: 29.0°C
                Voltage: 13.716 V
000776 - Cylinder 8
P0308 - 001 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 165926 km
Time Indication: 0
Date: 2021.02.03
Time: 17:56:09
         Freeze Frame:
                RPM: 640 /min
                Load: 18.8 %
                Speed: 0.0 km/h
                Temperature: 90.0°C
                Temperature: 32.0°C
                Voltage: 13.716 V
000777 - Cylinder 9
P0309 - 001 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 165926 km
Time Indication: 0
Date: 2021.02.03
Time: 17:56:15
         Freeze Frame:
                RPM: 639 /min
                Load: 18.8 %
                Speed: 0.0 km/h
                Temperature: 91.0°C
                Temperature: 32.0°C
                Voltage: 13.716 V
000769 - Cylinder 1
P0301 - 002 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 165926 km
Time Indication: 0
Date: 2021.02.03
Time: 18:11:36
         Freeze Frame:
                RPM: 621 /min
                Load: 22.0 %
                Speed: 0.0 km/h
                Temperature: 100.0°C
                Temperature: 57.0°C
                Voltage: 13.589 V
000773 - Cylinder 5
P0305 - 002 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 165926 km
Time Indication: 0
Date: 2021.02.03
Time: 18:11:36
         Freeze Frame:
                RPM: 621 /min
                Load: 22.0 %
                Speed: 0.0 km/h
                Temperature: 57.0°C
                Voltage: 13.589 V
000770 - Cylinder 2
P0302 - 002 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 165926 km
Time Indication: 0
Date: 2021.02.03
Time: 18:11:36
         Freeze Frame:
                RPM: 621 /min
                Load: 22.0 %
                Speed: 0.0 km/h
                Temperature: 57.0°C
                Voltage: 13.589 V
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 K HW: 4F0 959 655 D
Component: 7H AIRBAG AUDI8RH30 0400
Revision: 02H30000 Serial number: 003BMD0101Y%
Coding: 0014152
Subsystem 1 - Part No: 4F0 910 339 A
Component: BF-Gewichtsens. H02 0050
Subsystem 2 - Serial number: 6332CSME177B0B255
Subsystem 3 - Serial number: 6342CSME177B0B1FF
Subsystem 4 - Serial number: 6352QSME25323C45D
Subsystem 5 - Serial number: 6362QSME2523322FC
Subsystem 6 - Serial number: 63734SME206B175B1
Subsystem 7 - Serial number: 63834SME26042F4F7
2 Faults Found:
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
014 - Defective - Intermittent - MIL ON
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
001 - Upper Limit Exceeded - Intermittent - MIL ON
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90026070600289
Coding: 0012141
Shop #: WSC 02323 758 00200
VCID: 6695B3F0F467261BE9E-8032
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 980 Q
Component: KOMBIINSTR. M73 H20 0170
Revision: 00300000 Serial number: 5H335LY37
Coding: 2113268
Shop #: WSC 08307 444 124033
VCID: 2313EAE447D513334E0-8076
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B0731980BB
Coding: F5D1DEF7707A06
VCID: 6C81C1D8EA8B1C4BBFA-8038
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 119165 km
Time Indication: 0
Date: 2019.10.02
Time: 19:33:20
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H44 0390
Revision: 00044000 Serial number: AUZ5ZBG3172311
VCID: 1A6DD700709F52FB9D6-804E
1 Fault Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 7
Fault Frequency: 1
Reset counter: 234
Mileage: 150939 km
Time Indication: 0
Date: 2020.09.02
Time: 17:54:57
         Freeze Frame:
                Text: 00000000
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: 619FA0EC1D4941231CC-8034
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 D HW: 4E0 919 887 L
Component: MNS US H48 0970
Revision: 00000000 Serial number: 381CJ077520803
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00000000 Serial number: ™C`
Coding: 0051947
Shop #: WSC 02327 758 00200
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01038861370000
Coding: 4618269
VCID: 2E050BD01C17AE5BD1E-807A
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
1 Fault Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 212
Mileage: 0 km
Time Indication: 0
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H10 0240
Revision: PROD_01 Serial number: 00000000020452
Coding: 0000026
VCID: 2517F4FC49E1ED03204-8070
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000080295
Coding: 0012014
VCID: 5EE59B102C377EDB21E-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00000000 Serial number: hwb
Coding: 0051947
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04—
Coding: 0008022
Shop #: WSC 02324 758 00200
VCID: 2019E5E856C3082B532-8074
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000016
VCID: 290FF8CC25F9C96304C-807C
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 394D.077756049
Coding: 0000002
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000050251
Shop #: WSC 08167 444 54463
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2703300139
Coding: 344630393135313035442056413032373033333030313339
Shop #: WSC 00000 384 00290
5 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 163513 km
Time Indication: 0
Date: 2021.01.12
Time: 08:01:26
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 163513 km
Time Indication: 0
Date: 2021.01.12
Time: 08:06:14
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 163513 km
Time Indication: 0
Date: 2021.01.12
Time: 08:06:23
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 163513 km
Time Indication: 0
Date: 2021.01.12
Time: 08:06:34
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 163513 km
Time Indication: 0
Date: 2021.01.12
Time: 08:06:44
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0051754
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000703140057
Shop #: WSC 12336 024 394758
VCID: 343119B8F23B848BA7A-8060
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12— Serial number: 525PA8-J7220HU
Coding: 1000204
Shop #: WSC 02335 785 00200
VCID: 5DE79C1C213165C3384-8008
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0051754
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06230707919744
Coding: 0021306
Shop #: WSC 131071 1023 2097151
VCID: 270BFEF433EDFF13128-8072
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H18 1130
Revision: 00000000 Serial number: 00000005027679
Coding: 0010900
VCID: 2809FDC83EF3F06B1B2-807C
End----------(Elapsed Time: 02:10, VBatt start/end: 13.4V/14.0V)-----------
Update 104000 miles:
Replaced the intake manifold position sensor, which took about an hour. Started the car, ran a basic setting 142 in Engine Module, “go”, “ON”. Gave the ADP O.K. The adaptation and engine key cycling gave a roar and smooth idle I haven’t heard in some time. Gave it a 5 minute drive through some backroads.
The car is absolutely unbelievable with carbon cleaning, fresh plugs, coils, and purge valve. It like falling in love with that 10 who you know will leave soon, good. The exhaust, jdm 93 tune, serviced gearbox with jhm trans tune, light weight crank pulley.
The motor is so refined feeling, with torque everywhere. This is a treat of a lifetime honestly. I know one day I may not own this car, but I will cherish when she’s dialed in. I hope anyone reading this can experience this motor. It has its problems, but you pay to play. Its the greatest sounding car for under 20k… or 30k.
Oh and she’s getting another oil change tomorrow. MIGHT do fuel filter if the ground isn’t too cold.
Congrats. Great description of the ownership experience lol. Haven’t driven my car in anger in a couple years so I’ll probably have the same experience some time this spring. Godspeed to everyone in the Audi V10 love/hate relationship.
Oil change lead to running VCDS again to check codes. This time got a cylinder 5 open circuit fault. Engine II showed multiple misfires. Happy Valentines Day lol.
Quick read boils down to:
Coil pack - I am wondering if the Bremi coils I used are the culprit
Plug - waiting on JHM V10 support to verify plug gap, I had them set to .032".
Wiring
Injector
Swapped coil pack 5 with 3, and inspected plug 5, verified gap of .032”.
I noticed coolant on the floor, and found the cause:
The coolant expansion tank hosing had a hairline crack at this reduction point. I was able to cut another 3/8” of hose to the (now brass T) Y connection before the tank. Also gets a clamp fingers crossed. This was caused by me moving the hose out of the way to slip in the oil cap. Parts on order, note the new rev BB instead of AE” on the part.
Also spotted a hairline crack in the PCV valve side connection. Taped it with electrical tape for now.
Lesson learned , if the hoses are original at this point, it’s just a ticking time bomb for plastic anything. The rubber for the hosing looks in good shape.
Need to re run VCDS tomorrow, to see what is going on with the coil packs.
Oh and I spilled 10 quarts of old oil on a 3x6 portion of my driveway.
2/15 update, the jerry rig did not work, and the coolant sprayed out in less than 5 minutes of driving. I overtightened the clamp and crushed the aluminum part. I tryed to make it round again, and see if rtv sealant and (light) clamp pressure will hold it for the time being.
The thought is to go with a 3/8" barb to 3/16 barb, and replace the plastic with 3/16 ID rubber hosing. This will be tremendously cheaper, and service its purpose (as long as the OG rubber sections of the hose holds up). I know its not OEM, but I need to be sensible.
On a side note, with the car down, I’m going to get the OEM coil packs. Shout out to FCP Euro for providing a return and return shipment tag for the Bremi. They have excellent customer service, and are knowledgeable on the platform. Yes, I acknowledge it may be my wrongdoing.
Tuesday night I got the car running and drivable. The 3/8 air hosing I used to get to work was near thermal limits, so I ran to NAPA and bought 2 feet of SAE 30r14t2 fuel line hose, rated at 257 degrees Fahrenheit. 3/8” barbs on both ends with hose clamps.
Drove the car in sport the whole way home, and didn’t leak anymore coolant, temp was spot on. The stressful drive to work was rewarded with silky smooth midrange back home.
I have an oil leak coming from the rear of the motor (or at least the rear is where the drip is hitting.
Of course i cannot see anything from the top, the thick hose in the picture accumulates the oil. Anyone have any thoughts? Please dont say engine out… :sob:
I changed oil 2 weekends ago and noticed almost the exact same leak and was going to post it just haven’t gotten around to it. My initial thought was either the rear crankseal or the lower pan but I also can’t help wonder if it’s the rear diff either. Curious to see what others thoughts might be on this.
I take it rear crank seal is engine out, but how about lower pan? Rear diff too?
Probably rear crankshaft cover leaking. Engine out. Good luck.
I’m going to break down and have a euro specialty shop review. May be the death knell of my ownership honestly. Doing the rebuilds like some of you have is way over my skill set.
I’ll keep you all posted, staying positive it’s something dumb.
Damn best of luck I noticed I had that same oil back there way before I pulled my engine out. Maybe it was rear crank seal. I don’t even know. Hopefully it’s something else
Update on the leak(s):
The mechanic fixed 2 smaller leaks with oil cooler line o ring replacement. After fixing those he was able to isolate the main leak, which is transmission fluid from the bell housing. Engine out.
The painful decision is here, but I’m in an only deeper love spell from the S6, after driving a loaner Chrysler Pacifica with blown engine mounts and warped rotors for 3 weeks.
With the engine out:
All o2 sensors replaced
Power steering pump was found to be leaking, address that.
Fix the leak from the transmission, I’m thinking a new torque converter is needed, since I had the first gear slam since owning the car?
My mechanic doesn’t want to do any timing chain work on this motor.
@justincredible or @jludt am I missing anything obvious with the motor drop? I don’t have the funds to go super nuts, and the guy does not want to to timing components if he can help it, as he feels uncomfortable with the motor.
o2 sensors would be good to do.
No real need to do the TQ converter unless your getting a code right now.
For the most part it’s not really needed to do the timing components. It might not be bad to open up the back to just do a visual inspection but other than that.
The starter is a motor out job but they don’t tend to go out a lot.
Depending on your emmisions standards I would pull out the cats as they will start to go after a while and there is a healthy amount of performance there.
