Sorry for the dumb question, how do you determine its “good”?
Demoralizing Update:
Work was completed, and they did a test drive. Transmission fluid is coming out at the same rate from the bell housing as before the torque converter seal replacement. The mechanic suspects either:
a workmanship issue on the installation of the seal
new seal is defective
a separate seal on the transmission has failed and he misdiagnosed the issue. He mentioned that it should be better to identify since he cleaned up the bell housing before installation, as part of the installation process.
With the problems the mechanic had been reasonable, and is trying his best.
Fingers crossed again.
Small update:
Mechanic has the engine dropped again. He could not determine the failure point, or any obvious locations for a leak. Speaking to his transmission of specialist, the guy said he has seen an occurrence on a ZF where the torque converter is cracked. We are moving forward with redoing the converter. New converters at $2375 after a quick search.
Update:
Rebuild of the torque converter did the trick. No more leaking! Shop says it’s running like a champ. The shop dropped it off to the exhaust shop that fixed cracked flex pipe to address the other. I really should have requested that they install the muffler bypasses.
Now the but:
They said the dash analogue dials no longer work(temp, needles, rpm, speed), but the output sequence on VCDS doesn’t show any output issues. I suggested the look at grounding/common? He can’t find anything and the cluster was sent out to a specialist for diagnostics. Hope they find something simple to keep this project moving.
I’ve learned a lot about my appetite for stress over this car.
The TQ converter is a big pain in the back side. Great to hear you got it all sorted out. The TQ converter usually has the power seal go out and that can cause the issues.
It might be worth checking fuses and then a full code scan of the modules for electronics.
Great to hear the car is moving along again.
Yep.
Got her back last Thursday. After the entire fiasco, the torque converter rebuild did the trick. Having everything else taken care of is a nice feeling, after that big bill.
Installed the seats I purchased from @jolio1994. Repaired a few broken bits from the set, and had the front seat bottoms reupholstered. Gave the carpet a good cleaning with everything out. Completely changes the vibe of the car. Next is detailing the outside. I don’t think I should call this a salvage car anymore.
I remember when I swapped my interior and was able to do a deep clean on the carpets. Now my 07 has a “newish” car smell. Btw; magic eraser and a light rub on the steering wheel removes a lot of the shine. Worked wonders for me.
Man your TC issue has me a lil stressed. I have oil all over my passanger diff housing area and the coolant hoses like you. I hope it is coming from a place unrelated to the torque converter
Did you rebuild your TC or buy new? Were you able to see this crack in the TC or was it internal? I did not think the TCs went bad on the 6 speeds but I suppose there is always a case
Here’s what mine looks like. Similar
Hey LT,
I went with a rebuild ($650 vs 2400). They were unsure where the leak occurred (hairline crack in the housing vs a seal on the TC itself going bad). The entire area you show in that picture was covered in oil, and was hard to ID. I have a few shots of the area before I took it for service. Revolv0’s Salvage Rescue S6
The guy who did the rebuild said he’s seen 2 other cases where the TQ on the 6 speed required a rebuild. It’s not common.
My s6 is one of those that has zero shifting issues so am looking to stay optimistic.
Where did you ship the TC to be rebuilt if you can share?
Hesitant to share the transmission place until I find the root cause of a P0741 fault… related to the torque converter or TC solenoid.
I also have a P0175 system too rich bank 2 - driver side.
I already have replaced all o2 sensors, and N80 purge valve… could the MAF be going bad or dirty? I’ll try cleaning that first.
Divas…
Something that jumps at me as concern is the engine II P1084 fault below. Does that fault mean the O2 sensor is registering to rich of combustion from bank 3, or do I have a defective sensor?
004228 - Mixture Regulation; Bank 3; Range 2 **
** P1084 - 002 - Rich Limit Exceeded - Intermittent
** Freeze Frame:**
** Fault Status: 00100010**
** Fault Priority: 0**
** Fault Frequency: 4**
** Reset counter: 255**
** Mileage: 166746 km**
** Time Indication: 0**
** Date: 2021.07.30**
** Time: 07:39:27**
** Freeze Frame:**
** RPM: 2355 /min**
** Load: 27.0 %**
** Speed: 106.0 km/h**
** Temperature: 88.0°C**
** Temperature: 27.0°C**
** Absolute Pres.: 990.0 mbar**
** Voltage: 12.827 V**
02-Auto Trans – Status: Malfunction 0010
05-Acc/Start Auth. – Status: Malfunction 0010
07-Control Head – Status: Malfunction 0010
08-Auto HVAC – Status: Malfunction 0010
0F-Digital Radio – Status: Malfunction 0010
15-Airbags – Status: Malfunction 0010
1E-Media Player 2 – Status: Malfunction 0010
36-Seat Mem. Drvr – Status: Malfunction 0010
55-Headlight Range – Status: OK 0000
56-Radio – Status: OK 0000
61-Battery Regul. – Status: Malfunction 0010
76-Park Assist – Status: OK 0000
Address 01: Engine Labels:. User\07L-910-552-BSM1.lbl
Part No SW: 4F1 910 552 A HW: 4F1 907 552
Component: 5.2L JHM/V1 OCT9 ª0040
Revision: 59H14— Serial number:
Coding: 01050009190F0160
Shop #: WSC 02335 758 00200
VCID: 221DEFE058CF1A3BB97-8076
5 Faults Found:
008576 - Bank 2; System Too Rich off Idle
P2180 - 002 - - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 166745 km
Time Indication: 0
Date: 2021.07.30
Time: 07:39:00
Freeze Frame:
RPM: 2093 /min
Load: 33.3 %
Speed: 92.0 km/h
Temperature: 90.0°C
Temperature: 29.0°C
Voltage: 13.335 V
005668 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 166783 km
Time Indication: 0
Date: 2021.07.30
Time: 14:14:49
Freeze Frame:
RPM: 2267 /min
Load: 35.3 %
Speed: 99.0 km/h
Temperature: 92.0°C
Temperature: 34.0°C
Absolute Pres.: 980.0 mbar
Voltage: 13.462 V
008568 - Bank 1; System Too Rich off Idle
P2178 - 002 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 9
Reset counter: 255
Mileage: 166800 km
Time Indication: 0
Date: 2021.07.30
Time: 14:24:18
Freeze Frame:
RPM: 2365 /min
Load: 23.9 %
Speed: 107.0 km/h
Temperature: 88.0°C
Temperature: 27.0°C
Voltage: 12.700 V
001110 - EVAP System
P0456 - 001 - Very Small Leak Detected
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 166978 km
Time Indication: 0
Date: 2021.08.02
Time: 07:16:02
Freeze Frame:
RPM: 1693 /min
Load: 26.3 %
Speed: 45.0 km/h
Temperature: 66.0°C
Temperature: 18.0°C
Voltage: 13.081 V
P1923 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 167271 km
Time Indication: 0
Date: 2021.08.03
Time: 16:24:27
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 53.0°C
Temperature: 53.0°C
Voltage: 11.557 V
Readiness: 0000 0001
Part No SW: 4F2 910 156 M HW: 09E 927 156 C
Component: AG6 09E 5,2 FSI USA 0030
Revision: --H01— Serial number: 0104372
Coding: 0000002
Shop #: WSC 13622 410 403014
VCID: 2F3B16D41B1DA753269-807A
1 Fault Found:
001857 - Torque Converter Clutch
P0741 - 000 - Stuck OFF / No Power being transferred
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 166704 km
Time Indication: 0
Date: 2021.07.30
Time: 07:15:46
Freeze Frame:
RPM: 2496 /min
RPM: 2400 /min
RPM: 3488 /min
(no units): 70.0
(no units): 60.0
Temperature: 67.0°C
T.B. Angle: 23.5°
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Coding: 0020920
Shop #: WSC 02325 758 00200
VCID: 313F10AC0D29B1A330D-8064
No fault code found.
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 A HW: 4F0 905 852 C
Component: FBSAUDIC6 ELVSG H01 0030
Revision: 31050601 Serial number: 10601200717004
Coding: 0000015
Shop #: WSC 52597 004 1048576
VCID: 2411E9F842DB140BCBB-8070
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0053
1 Fault Found:
00955 - Key 1
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110010
Fault Priority: 3
Fault Frequency: 4
Reset counter: 156
Mileage: 164335 km
Time Indication: 0
Date: 2006.03.15
Time: 18:26:27
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 R HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 361CI077513226
Coding: 0010003
Shop #: WSC 02334 758 00200
VCID: 323D1FA0082F8ABB497-8066
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000000722774
Subsystem 3 - Serial number: 0104.04.070000000100010914ÿ
Subsystem 4 - Serial number: 010914ÿ
1 Fault Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 82
Mileage: 164335 km
Time Indication: 0
Date: 2006.03.15
Time: 18:03:11
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000052 Serial number: 00000030227633
Coding: 0524330
VCID: 1C61D1187AAB2CCB73B-8048
1 Fault Found:
01854 - Heated Seat; Front Right (Z46)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 4
Reset counter: 159
Mileage: 164621 km
Time Indication: 0
Date: 2021.07.06
Time: 16:36:28
Freeze Frame:
Temperature: 49.0°C
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0115123
VCID: 303915A80623B8AB3F3-8064
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1 (R192) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 HW: 4E0 035 785
Component: SG ext.Player H09 0170
Revision: 00000000
VCID: 6597B4FC05612D031C5-8030
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 H HW: 4E0 035 593 D
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7G0071800
Shop #: WSC 00000 000 00000
VCID: 2C0101D82A0BDC4B03B-8078
Address 11: Engine II Labels:. User\07L-910-552-BSM2.lbl
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 166746 km
Time Indication: 0
Date: 2021.07.30
Time: 07:39:27
Freeze Frame:
RPM: 2355 /min
Load: 27.0 %
Speed: 106.0 km/h
Temperature: 88.0°C
Temperature: 27.0°C
Voltage: 12.827 V
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 K HW: 4F0 959 655 D
Component: 7H AIRBAG AUDI8RH30 0400
Revision: 02H30000 Serial number: 003BMD0101Y%
Coding: 0014152
Subsystem 1 - Part No: 4F0 910 339 B
Component: BF-Gewichtsens. H03 0060
Subsystem 2 - Serial number: 6332CSME177B0B255
Subsystem 3 - Serial number: 6342CSME177B0B1FF
Subsystem 4 - Serial number: 6352QSME25323C45D
Subsystem 5 - Serial number: 6362QSME2523322FC
Subsystem 6 - Serial number: 63734SME206B175B1
Subsystem 7 - Serial number: 63834SME26042F4F7
4 Faults Found:
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
014 - Defective - Intermittent - MIL ON
02511 - Control Module for Seat Occupied Recognition (J706)
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
01217 - Side Airbag Igniter; Driver Side (N199)
001 - Upper Limit Exceeded - MIL ON
01213 - Belt Tensioner Igniter; Rear Middle (N198)
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90026070600289
Coding: 0012141
Shop #: WSC 02323 758 00200
VCID: 6695B3F0F467261B15F-8032
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 980 Q
Component: KOMBIINSTR. M73 H18 0110
Revision: 00300000 Serial number: 5H3375R76
Coding: 0065228
VCID: 2313EAE447D51333B21-8076
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B0731980BB
Coding: F5D1DEF7707A06
VCID: 6C81C1D8EA8B1C4B43B-8038
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H44 0390
Revision: 00044000 Serial number: AUZ5ZBG3172311
VCID: 1A6DD700709F52FB617-804E
1 Fault Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 7
Fault Frequency: 1
Reset counter: 82
Mileage: 164335 km
Time Indication: 0
Date: 2006.03.15
Time: 17:18:16
Freeze Frame:
Text: 00000000
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
Shop #: WSC 02334 785 00200
VCID: 619FA0EC1D494123E0D-8034
3 Faults Found:
00003 - Control Module
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 136
Mileage: 17496 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:00
01446 - Sensor for Driver Seat; Seatback Adjust (G230)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 136
Mileage: 17496 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:00
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 136
Mileage: 17496 km
Time Indication: 0
Date: 2007.03.02
Time: 12:54:22
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 D HW: 4E0 919 887 L
Component: MNS US H48 0970
Revision: 00000000 Serial number: 381CJ077520803
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00000000 Serial number: ™C`
Coding: 0051947
Shop #: WSC 02327 758 00200
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01038861370000
Coding: 4618269
VCID: 2E050BD01C17AE5B2DF-807A
1 Fault Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 136
Mileage: 0 km
Time Indication: 0
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H10 0240
Revision: PROD_01 Serial number: 00000000020452
Coding: 0000026
VCID: 2517F4FC49E1ED03DC5-8070
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000080295
Coding: 0012014
VCID: 5EE59B102C377EDBDDF-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00000000 Serial number: hwb
Coding: 0051947
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04—
Coding: 0008022
Shop #: WSC 02324 758 00200
VCID: 2019E5E856C3082BAF3-8074
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000016
VCID: 290FF8CC25F9C963F8D-807C
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 394D.077756049
Coding: 0000002
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000050251
Shop #: WSC 08167 444 54463
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2703300139
Coding: 344630393135313035442056413032373033333030313339
Shop #: WSC 00000 384 00290
5 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 5
Reset counter: 255
Mileage: 164335 km
Time Indication: 0
Date: 2006.03.15
Time: 17:29:06
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Mileage: 164335 km
Time Indication: 0
Date: 2006.03.15
Time: 17:35:11
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 164335 km
Time Indication: 0
Date: 2006.03.15
Time: 17:35:21
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 164336 km
Time Indication: 0
Date: 2006.03.15
Time: 12:34:09
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 164336 km
Time Indication: 0
Date: 2006.03.15
Time: 12:34:19
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0051754
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000703140057
Shop #: WSC 12336 024 394758
VCID: 343119B8F23B848B5BB-8060
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12— Serial number: 525PA8-J7220HU
Coding: 1000204
Shop #: WSC 02335 785 00200
VCID: 5DE79C1C213165C3C45-8008
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0051754
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06230707919744
Coding: 0021306
Shop #: WSC 131071 1023 2097151
VCID: 270BFEF433EDFF13EE9-8072
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H18 1130
Revision: 00000000 Serial number: 00000005027679
Coding: 0010900
VCID: 2809FDC83EF3F06BE73-807C
End----(Elapsed Time: 02:07, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
On the highway today, and I noticed the car sounding funny. The funny turned into a full metal clanking noise, which lit up the dash. I didn’t have my laptop to diagnose the issue, but I heard it from the back of the motor.
The dash lights lit up and when I parked it, the motor stalled in drive. I fired the car back up again, to the current noise level it’s at now.
Oh boy, here we go again. Luckily, I already had the engine dropped scheduled (again again), to address the defective seal in the torque converter. Fingers crossed again boys.
Wow, that is some scary audio. If it’s from the top, look at the valve train. If it’s from below, think crank/rods/bearings.
Whatever it is, don’t run it until you get a chance to check it.
Ed
I bet for a rod on my side… it’s an awful noise, be prepared for an engine replacement…
Oh no. Good luck. Hopefully it’s just something simple on the exterior of the motor. You could see slight smoke coming from behind the motor so maybe a timing component? Godspeed.
Crank is broken , with play at the transmission side.
To personify the car may sound ridiculous, but it’s heart is broken. I loved it for the NA experience it provided, the noise, the instant throttle response. I don’t think I’ll put another motor in it, but then again will be erasing the car. The whole theme of this thread was the junk yard rescue. When do you put down an old dog?
Conflicted. I think I can get some coin for the JHMmintake, crank pulley, ecus, injectors, accessories. Anyone else have a suggested parts list to harvest before scrapping?
Dude that really really sucks. I just went back and read almost this entire thread to get an idea of the journey you’ve been on (you purchased yours right after mine I believe) and I really feel for you. Did this same shop who was doing your previous engine drops diagnose this?
That sucks I’m sorry to hear
How the hell does the crank break?
