Update from the Christmas carbon cleaning / plug replacement / Coil pack replacement at 101500 miles…
When taking off the JHM intake manifold, I may have tweeked one of the intake runner arms (i felt a ‘click’ on the left arm when working the intake off). Note to future members, dont mess with the arms with taking off, putting on the intake!
Performed the carbon cleaning installed another set of NGK 5592 plugs, installed the BREMI coil packs (original were dated in 07, so it was time).
Started the car back up, cleared the codes in VCDS and got the following codes: P2014 and misfires out the ass. Note, the car runs, idles, drives like shit. The misfiring is concerning. I looked at blackwidows intake code post, and the sock ordeal for some insight. I plan to take the intake off, should it just be a matter or replacing the intake position sensor for bank 1? If so, part number? Bank 1 should be number one in the picture below?
VIN: WAUGN94F67N150224 Mileage: 165920km-103097miles
05-Acc/Start Auth. – Status: Malfunction 0010
07-Control Head – Status: Malfunction 0010
09-Cent. Elect. – Status: Malfunction 0010
0F-Digital Radio – Status: Malfunction 0010
15-Airbags – Status: Malfunction 0010
19-CAN Gateway – Status: Malfunction 0010
1E-Media Player 2 – Status: Malfunction 0010
55-Headlight Range – Status: OK 0000
56-Radio – Status: OK 0000
61-Battery Regul. – Status: Malfunction 0010
76-Park Assist – Status: OK 0000
Address 01: Engine Labels:. User\07L-910-552-BSM1.lbl
Part No SW: 4F1 910 552 A HW: 4F1 907 552
Component: 5.2L JHM/V1 OCT9 ª0040
Revision: 59H14— Serial number:
Coding: 01050009190F0160
Shop #: WSC 02335 758 00200
VCID: 221DEFE058CF1A3B456-8076
2 Faults Found:
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 165926 km
Time Indication: 0
Date: 2021.02.03
Time: 18:10:21
Freeze Frame:
RPM: 650 /min
Load: 16.1 %
Speed: 0.0 km/h
Temperature: 98.0°C
Temperature: 55.0°C
Absolute Pres.: 980.0 mbar
Voltage: 13.970 V
008212 - Intake Manifold Flap Position Sensor (Bank 1)
P2014 - 002 - Electrical Malfunction
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 165926 km
Time Indication: 0
Date: 2021.02.03
Time: 18:10:21
Freeze Frame:
RPM: 325 /min
Load: 30.6 %
Speed: 0.0 km/h
Temperature: 98.0°C
Temperature: 55.0°C
Voltage: 12.446 V
Readiness: 0110 0101
Part No SW: 4F2 910 156 M HW: 09E 927 156 C
Component: AG6 09E 5,2 FSI USA 0030
Revision: --H01— Serial number: 0104372
Coding: 0000002
Shop #: WSC 13622 410 403014
VCID: 2F3B16D41B1DA753DA8-807A
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Coding: 0020920
Shop #: WSC 02325 758 00200
VCID: 313F10AC0D29B1A3CCC-8064
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 A HW: 4F0 905 852 C
Component: FBSAUDIC6 ELVSG H01 0030
Revision: 31050601 Serial number: 10601200717004
Coding: 0000007
Shop #: WSC 05194 003 1048576
VCID: 2411E9F842DB140B37A-8070
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0053
1 Fault Found:
00955 - Key 1
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01110010
Fault Priority: 3
Fault Frequency: 5
Reset counter: 210
Mileage: 159915 km
Time Indication: 0
Date: 2020.11.19
Time: 07:10:02
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 R HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 361CI077513226
Coding: 0010003
Shop #: WSC 02334 758 00200
VCID: 323D1FA0082F8ABBB56-8066
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000000722774
Subsystem 3 - Serial number: 0104.04.070000000100010914ÿ
Subsystem 4 - Serial number: 010914ÿ
2 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 205
Mileage: 119165 km
Time Indication: 0
Date: 2019.10.02
Time: 19:49:53
01964 - Control Module for Seat & Steering Column Memory (J136)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 218
Mileage: 163513 km
Time Indication: 0
Date: 2021.01.12
Time: 12:06:24
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000052 Serial number: 00000030227633
Coding: 0524330
VCID: 1C61D1187AAB2CCB8FA-8048
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0115123
VCID: 303915A80623B8ABC32-8064
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 02335
1 Fault Found:
01494 - Bulb for Parking Lamps; Left (M1)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 249
Mileage: 165700 km
Time Indication: 0
Date: 2021.01.30
Time: 07:55:00
Address 0E: Media Player 1 (R192) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 HW: 4E0 035 785
Component: SG ext.Player H09 0170
Revision: 00000000
VCID: 6597B4FC05612D03E04-8030
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 H HW: 4E0 035 593 D
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7G0071800
Shop #: WSC 00000 000 00000
VCID: 2C0101D82A0BDC4BFFA-8078
Address 11: Engine II Labels:. User\07L-910-552-BSM2.lbl
9 Faults Found:
P0300 - 001 -
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 165926 km
Time Indication: 0
Date: 2021.02.03
Time: 17:54:56
Freeze Frame:
RPM: 629 /min
Load: 20.0 %
Speed: 0.0 km/h
Temperature: 89.0°C
Temperature: 24.0°C
Voltage: 13.843 V
000774 - Cylinder 6
P0306 - 001 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 165926 km
Time Indication: 0
Date: 2021.02.03
Time: 17:54:56
Freeze Frame:
RPM: 629 /min
Load: 20.0 %
Speed: 0.0 km/h
Temperature: 89.0°C
Temperature: 24.0°C
Voltage: 13.843 V
000784 - Cylinder 10
P0310 - 001 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 165926 km
Time Indication: 0
Date: 2021.02.03
Time: 17:54:58
Freeze Frame:
RPM: 642 /min
Load: 20.0 %
Speed: 0.0 km/h
Temperature: 88.0°C
Temperature: 24.0°C
Voltage: 13.970 V
000775 - Cylinder 7
P0307 - 001 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 165926 km
Time Indication: 0
Date: 2021.02.03
Time: 17:55:28
Freeze Frame:
RPM: 645 /min
Load: 20.8 %
Speed: 0.0 km/h
Temperature: 87.0°C
Temperature: 29.0°C
Voltage: 13.716 V
000776 - Cylinder 8
P0308 - 001 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 165926 km
Time Indication: 0
Date: 2021.02.03
Time: 17:56:09
Freeze Frame:
RPM: 640 /min
Load: 18.8 %
Speed: 0.0 km/h
Temperature: 90.0°C
Temperature: 32.0°C
Voltage: 13.716 V
000777 - Cylinder 9
P0309 - 001 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 165926 km
Time Indication: 0
Date: 2021.02.03
Time: 17:56:15
Freeze Frame:
RPM: 639 /min
Load: 18.8 %
Speed: 0.0 km/h
Temperature: 91.0°C
Temperature: 32.0°C
Voltage: 13.716 V
000769 - Cylinder 1
P0301 - 002 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 165926 km
Time Indication: 0
Date: 2021.02.03
Time: 18:11:36
Freeze Frame:
RPM: 621 /min
Load: 22.0 %
Speed: 0.0 km/h
Temperature: 100.0°C
Temperature: 57.0°C
Voltage: 13.589 V
000773 - Cylinder 5
P0305 - 002 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 165926 km
Time Indication: 0
Date: 2021.02.03
Time: 18:11:36
Freeze Frame:
RPM: 621 /min
Load: 22.0 %
Speed: 0.0 km/h
Temperature: 57.0°C
Voltage: 13.589 V
000770 - Cylinder 2
P0302 - 002 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 165926 km
Time Indication: 0
Date: 2021.02.03
Time: 18:11:36
Freeze Frame:
RPM: 621 /min
Load: 22.0 %
Speed: 0.0 km/h
Temperature: 57.0°C
Voltage: 13.589 V
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 K HW: 4F0 959 655 D
Component: 7H AIRBAG AUDI8RH30 0400
Revision: 02H30000 Serial number: 003BMD0101Y%
Coding: 0014152
Subsystem 1 - Part No: 4F0 910 339 A
Component: BF-Gewichtsens. H02 0050
Subsystem 2 - Serial number: 6332CSME177B0B255
Subsystem 3 - Serial number: 6342CSME177B0B1FF
Subsystem 4 - Serial number: 6352QSME25323C45D
Subsystem 5 - Serial number: 6362QSME2523322FC
Subsystem 6 - Serial number: 63734SME206B175B1
Subsystem 7 - Serial number: 63834SME26042F4F7
2 Faults Found:
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
014 - Defective - Intermittent - MIL ON
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
001 - Upper Limit Exceeded - Intermittent - MIL ON
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90026070600289
Coding: 0012141
Shop #: WSC 02323 758 00200
VCID: 6695B3F0F467261BE9E-8032
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 980 Q
Component: KOMBIINSTR. M73 H20 0170
Revision: 00300000 Serial number: 5H335LY37
Coding: 2113268
Shop #: WSC 08307 444 124033
VCID: 2313EAE447D513334E0-8076
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B0731980BB
Coding: F5D1DEF7707A06
VCID: 6C81C1D8EA8B1C4BBFA-8038
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 119165 km
Time Indication: 0
Date: 2019.10.02
Time: 19:33:20
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H44 0390
Revision: 00044000 Serial number: AUZ5ZBG3172311
VCID: 1A6DD700709F52FB9D6-804E
1 Fault Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 7
Fault Frequency: 1
Reset counter: 234
Mileage: 150939 km
Time Indication: 0
Date: 2020.09.02
Time: 17:54:57
Freeze Frame:
Text: 00000000
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: 619FA0EC1D4941231CC-8034
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 D HW: 4E0 919 887 L
Component: MNS US H48 0970
Revision: 00000000 Serial number: 381CJ077520803
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00000000 Serial number: ™C`
Coding: 0051947
Shop #: WSC 02327 758 00200
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01038861370000
Coding: 4618269
VCID: 2E050BD01C17AE5BD1E-807A
1 Fault Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 212
Mileage: 0 km
Time Indication: 0
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H10 0240
Revision: PROD_01 Serial number: 00000000020452
Coding: 0000026
VCID: 2517F4FC49E1ED03204-8070
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000080295
Coding: 0012014
VCID: 5EE59B102C377EDB21E-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00000000 Serial number: hwb
Coding: 0051947
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04—
Coding: 0008022
Shop #: WSC 02324 758 00200
VCID: 2019E5E856C3082B532-8074
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000016
VCID: 290FF8CC25F9C96304C-807C
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 394D.077756049
Coding: 0000002
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000050251
Shop #: WSC 08167 444 54463
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2703300139
Coding: 344630393135313035442056413032373033333030313339
Shop #: WSC 00000 384 00290
5 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 163513 km
Time Indication: 0
Date: 2021.01.12
Time: 08:01:26
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 163513 km
Time Indication: 0
Date: 2021.01.12
Time: 08:06:14
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 163513 km
Time Indication: 0
Date: 2021.01.12
Time: 08:06:23
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 163513 km
Time Indication: 0
Date: 2021.01.12
Time: 08:06:34
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 163513 km
Time Indication: 0
Date: 2021.01.12
Time: 08:06:44
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0051754
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000703140057
Shop #: WSC 12336 024 394758
VCID: 343119B8F23B848BA7A-8060
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12— Serial number: 525PA8-J7220HU
Coding: 1000204
Shop #: WSC 02335 785 00200
VCID: 5DE79C1C213165C3384-8008
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0051754
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06230707919744
Coding: 0021306
Shop #: WSC 131071 1023 2097151
VCID: 270BFEF433EDFF13128-8072
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H18 1130
Revision: 00000000 Serial number: 00000005027679
Coding: 0010900
VCID: 2809FDC83EF3F06B1B2-807C
End----------(Elapsed Time: 02:10, VBatt start/end: 13.4V/14.0V)-----------
