Hi Guys
I need the stock rods specifications: 2.7 v6 tt
- Center To Center Distance: mm ?
- Big End / Journal Hole Diameter: mm ?
- Small End / Piston Pin Hole Diameter: mm ?
- Big End Thickness: mm ?
- Small End Thickness: mm ?
- the engine bore (cylinder diameter) too: mm?
Thanks in advance for your time.
Regards
