Justincredible,
Sorry for the long delay… got sidetracked by some work.
I’ll keep any further back and forth to this thread, sorry for not doing so in the first place.
After a couple weeks with no CEL (but experiencing the rough feeling as described in my last post) I finally got a CEL that popped on after coming to a stop at an offramp on the highway. Car began to stumble a bit. Made it to a grocery store, came back out 30 min later, and it seemed just fine, but still with the same rough symptoms as before on throttle.
Just pulled codes - pulling coils/plugs for inspection. Will be replacing plugs and using dielectric grease this time around between the plug and the coil. Seemed to help this last time.
1 Fault Found:
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 166250 km
Time Indication: 0
Date: 2016.05.18
Time: 15:12:09
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 12.0°C
Temperature: 18.0°C
Absolute Pres.: 970.0 mbar
Voltage: 11.811 V
6 Faults Found:
P0300 - 001 - - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 164458 km
Time Indication: 0
Date: 2016.04.26
Time: 14:47:59
Freeze Frame:
RPM: 563 /min
Load: 23.5 %
Speed: 0.0 km/h
Temperature: 93.0°C
Temperature: 18.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.351 V
000775 - Cylinder 7
P0307 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 164458 km
Time Indication: 0
Date: 2016.04.26
Time: 14:47:59
Freeze Frame:
RPM: 563 /min
Load: 23.5 %
Speed: 0.0 km/h
Temperature: 93.0°C
Temperature: 18.0°C
Voltage: 14.351 V
000771 - Cylinder 3
P0303 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 164458 km
Time Indication: 0
Date: 2016.04.26
Time: 14:47:59
Freeze Frame:
RPM: 563 /min
Load: 23.5 %
Speed: 0.0 km/h
Temperature: 93.0°C
Temperature: 18.0°C
Voltage: 14.351 V
000776 - Cylinder 8
P0308 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 164458 km
Time Indication: 0
Date: 2016.04.26
Time: 14:47:59
Freeze Frame:
RPM: 563 /min
Load: 23.5 %
Speed: 0.0 km/h
Temperature: 93.0°C
Temperature: 18.0°C
Voltage: 14.351 V
000769 - Cylinder 1
P0301 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 165954 km
Time Indication: 0
Date: 2016.05.15
Time: 00:00:36
Freeze Frame:
RPM: 4019 /min
Load: 78.0 %
Speed: 59.0 km/h
Temperature: 95.0°C
Temperature: 17.0°C
Voltage: 13.589 V
000774 - Cylinder 6
P0306 - 001 - Misfire Detected
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 166214 km
Time Indication: 0
Date: 2016.05.16
Time: 16:35:01
Freeze Frame:
RPM: 2604 /min
Load: 17.2 %
Speed: 120.0 km/h
Temperature: 93.0°C
Temperature: 15.0°C
Absolute Pres.: 980.0 mbar
Voltage: 14.097 V
