Rough driving issues
I’ve been having issues with my 2007 S6 for awhile. I don’t drive it all that much during the week. On a cold start it just runs rough but that’s somewhat expected. Right now I’m just living with a check engine light. Its usually a misfire on cylinders 4 and 8. I’ve got all new spark plugs and coils.
Driving with the engine at about 2200 to 3700 rpm and I give it lots of throttle causes the car to hesitate like its misfiring. If I downshift a gear or two and brings the revs up then I don’t feel it. If I’m cursing at about 40 in 6th gear in manual mode and I floor it to load the engine up at about 1500rpms then it doesn’t have the hesitating feeling. If I’ve got a vacuum leak then I cant find it. Is there some place under the manifold to maybe look? Everything before the throttle bodies is tight and the oil separator hose coming from the valve covers is new. I’m lost on what to try next.
Went to get an alignment today and before I went I was checking over things with the vagcom reader. Here are two things I’ve noticed
Notice all the failed status. Does this just point to needing new O2 sensors?
https://scontent-atl3-1.xx.fbcdn.net/v/t1.0-9/65216787_10214805119254066_7313500320565297152_n.jpg?_nc_cat=100&_nc_oc=AQlZcoF9jXbSWXp2jSited8DdQvVwb3IknW2HMGA_A0cHGON9dhKxNOey654j9utssc&_nc_ht=scontent-atl3-1.xx&oh=f5a9fe27313e75e579ab247538f2dacb&oe=5DBA9323
I also went under the measuring blocks for the engine and chose block 32 and it does not show many any numbers. It has in the past. Is the ECU ignoring O2 sensor readings?
https://scontent-atl3-1.xx.fbcdn.net/v/t1.0-9/64971296_10214805119054061_6670073464679825408_n.jpg?_nc_cat=106&_nc_oc=AQmb2S2MJGURau7x3yVaMYoUunRlIPio_pKJkW9qMJ_oEz9sJajGD0uCxNWRAnaREj4&_nc_ht=scontent-atl3-1.xx&oh=8ab7158c187095ffec061d5d34e1dcc0&oe=5D870A1A
