I have tested this a bunch of times, but recently did so on a hot night so I’ll use those numbers since they’re freshest in my head. I wanted to figure out what the best approach was. The RS4 gearing is unlike the other S cars out there. 2nd gear revs out to 70 mph. 3rd hits 101 mph or so.
So, when doing a 60-90 test in the RS4, you have two options
- start in 3rd, rev it out, no shifting
- start in 2nd, rev it out to the top, shift into 3rd, rev it out
Not that the 60-90 metric is one that anyone gives a shit about but if you’re doing a highway pull with a friend from 50 or 60 mph up to whatever speed you like, it’s valuable information to know what gear to start in. I did some pulls with a member here in his 335i a while back, and we started at about 55 mph. When I did so in 3rd, the car just felt like it was laggy up until it got into the big RPMs. When I started in 2nd, it jumped hard right away thanks to the RPMs being up, but I had to throw an extra gear shift in there. I wondered if the shifting ate up the improved acceleration?
In option 1 you will be going from 60-90 in third a.k.a. around 4800 RPM to just before redline. If you are doing a pull from 50-?? MPH, you are starting in third at only 4000 RPM. This is where the car seems to lag a bit. from 5500 and up the car feels a lot stronger.
When I did 60-90 rips just in 3rd gear, the pbox spit out 4.6 to 4.7 seconds. Mostly 4.6.
When I repeated the test, but started in 2nd gear the outcome was a little different. 60MPH in second gear = around 7000 RPM so this sounds dubious at best. You have to remember that you’re not starting the test (or pulls) at 60…probably 50 mph and rolling through. When you start at 50 MPH you’re ‘only’ at 5800 RPM so that leaves you with 2400 RPM of headroom before you need to shift into 3rd.
When I did 60-90 rips in 2nd, shifting into 3rd, the pbox said 4.5 seconds 4 out of 4 times I tried it. Further I did the 2-3 test AFTER the 3rd alone testing…so the car was PLENTY hot by the time I tried the 2-3 which can only hurt the 2-3 results. Despite that they were better.
Now I imagine you have to be a pretty quick shifter for this to make sense…and you have to be a big geek to care about that tenth etc. but that can be a car length in a pull. Anyway, thought I’d share it.
