Good info listed here, I’m sure you’ve seen this though.
http://audirevolution.net/forum/index.php?topic=172.0
- Tools - I used the same bristle like tools in the link above. In addition I had some older pic like tools meant for trim pieces for the hard little caked on spots that the brushes wouldn’t remove. I also tied a small rope to the tip of one of the bristle brush tool to help bend the tool around the back of the valves in a sort of controlled manner. I couldn’t seem to get it to bend at the exact spot I wanted without the rope.
Obviously the sockets/wrenches needed to remove and reassemble. Sorry, I didn’t take note of each size/tool used.
Access to a manual (Bentley, ETKA, ELSA, EBAHN etc also helped.
Tips:
Seems simple but tape off your front fenders. You are constantly leaning on them during the job and you don’t want to f’ them up.
Stretch often - lol - I’m in my 30’s and am at the gym 6 days a week. My back, neck, shoulders and knees were sore as hell the next day.
Be patient - once the I/M is off and you are ready to start it took me almost 45 minutes per set of valves.
I too soaked the closed valves to help loosen stuff. I used a combo of stuff. I first sprayed carb cleaner and then I drowned them in sea foam. I may try a different solution next time.
Pay close attention to the vacuum lines when assembling. Also take special care with the I/M, those rocker arms can be fragile especially in the colder garages during the winter months.
- I hope someone with camera skills does one. A nice time lapse video with the pertinent steps in slow motion and text scrolling at the bottom with specifics would be key!
