Which of the two 614 relays under the ECU is it?
I’m getting 13+ volts on my leak detection pump and both rear O2 sensors. Are both of those components run by the same relay?
Not sure what one it is but I was going to tell you its under the ECU. The ECU runs the 02 sensors and works to power them. Not sure if that was an answer to your question
