RS4 Fuel System - Preventative Maintenance
So as my car is creeping closer to 100k miles, I want to do some preventative maintenance on the fuel system.
So far I’ve got the following on my list:
Left high pressure fuel pump: 079127025AF
Right high pressure fuel pump: 079127026AB
2x HPFP to cylinder head o-ring: WHT005184
6x HPFP bolts: N10622101
I’ve made some sense of the fuel pressure sensors involved:
High pressure sensor: 06J906051C
Low pressure sensor: 06E906051K
The install of the pumps and sensors went well. The extra o-rings were not necessary as new ones came with the pumps, but they came in handy anyway since I broke one of the o-rings when I inserted the pump.
On the high pressure sensor, make sure that sucker is pretty tight. I just tightened the new one so it was aligned like the original sensor, which wasn’t enough. Of course I didn’t realize that until I turned on the fuel system and it was leaking into the valley.
I’ll order a low pressure pump on my next round of parts.
Is it worth replacing the fuel pressure regulating valve on each fuel rail? Has anyone seen failures on these? It’s pretty expensive for what is essentially a check valve. NOPE
[s]Looks like the ECS parts catalog is screwed up for the fuel pressure regulator. They list 06E906051K as a low pressure fuel sensor while the Audi parts catalog lists 06E906051K as the fuel pressure regulator. ECS says the fuel pressure regulating valve is 079130757.
What do I actually need with regards to the fuel pressure regulator(s)?[/s]
