Okay, so it’s time we talk about this…
Most people don’t think twice about this system. Like other bits on the car, if it doesn’t make horsepower or cause problems, it’s an ‘out of sight, out of mind’ kinda thing…
Background for those unfamiliar with how the system works. In our engine, when a single piston moves up and down in the cylinder, it’s moving ~ .525L of air. Pulled in from the intake, pushed out through the exhaust, everyone knows that. But that same piston is also moving .525L of air inside the block as well. Now I’m sure you’re saying ‘but there’s another piston going up at the same time, so it’s a net zero’…true, but not exactly. That .525L of air still has to move from one cylinder to another. That air has mass, that mass causes resistance. That mass is moving around inside the block from cylinder to cylinder at 137 times/second at full song. Additionally, any blow-by past the piston rings will increase the amount of air in the block. The more air, more mass, more pressure, more resistance…
Engine designers take this into account when designing the inside of the block, but there’s only so much that can be done with passage and bridge design.
Race engine builders get this…they run vacuum pumps to evacuate air out of the block, to the tune of 40cm Hg and more. Less air, less mass, less resistance… Another inherent benefit is the vacuum in the block also assists in seating the rings. So now you’re probably thinking, ‘Yup, let’s all just run as much vacuum as possible. Problem solved, right?’ …not exactly. Running that much vac inside the crankcase puts pressure on every gasket and seal between the block and the atmosphere (f/r main seals, vc gaskets, timing case covers, coolant pass-through pipes, dip stick, & oil cap). Any vac leak in the block means you’re potentially pulling debris into the crankcase. Race engines are rebuilt more frequently, thus this isn’t a huge deal. Run that motor for 200k…well you get the idea.
Now what about the inverse situation: Positive crankcase pressure due to a clogged, malfunctioning, or undersized PCV system. Where does that air go? All those seals I mentioned above are still affected. Do you happen to have a leaky front main seal? Leaky valve covers? Leaky dipstick seal? All the above? Well what about one more: intake valve seals (some of you probably know where I’m going with this). The intake ports are under vac, meaning the bottom of the seal is under vac. Combine that with the top of the seal under positive pressure, and guess where your oil is going to go…
Now onto how the PCV system on the RS4 works.
I’ll preface this by saying the RS4 has a system designed to work efficiently on a new motor & to pass emissions.
The components:
-There is a breather from the air intake snorkel to the block. It connects just before the TB on the back side, and the other end feeds to the valley underneath the IM. There’s a check valve (rubber diaphragm) that only allows air to flow from the intake to the block, and not the other way around.
-Both valve covers have ports that join together on drivers side and feed into the oil separator. That oil separator has a piston that will compress depending on air flow, through a series of 3 cyclonic oil separators. The air then flows through a diaphragm & restrictor plate to the IM. The oil drains out the bottom of the separator via hose that runs to the valley directly adjacent to the aforementioned breather hose. If you’ve done a carbon clean before, you’ve seen all of this…hopefully I’m connecting the dots on what it’s all doing…
Onto the PCV itself, here’s an exploded view:
http://i172.photobucket.com/albums/w2/koolade9/Ibis%20RS4/IMG_9267_zpsxjhsklnf.jpg
The diaphragm serves two purposes, sealing the cap, and creates an adjustable cavity depending on vac/flow:
http://i172.photobucket.com/albums/w2/koolade9/Ibis%20RS4/IMG_9263_zpsl78egzs8.jpg
Now you see two plastic parts, one is a spring seat, the other is a restrictor:
http://i172.photobucket.com/albums/w2/koolade9/Ibis%20RS4/IMG_9265_zpsawt61qxc.jpg
In stock form, the crankcase maintains ~4cm Hg of vac (which is almost nothing):
http://i172.photobucket.com/albums/w2/koolade9/Ibis%20RS4/IMG_9262_zps8gkvslio.jpg
While the IM maintains ~46cm Hg of vac:
http://i172.photobucket.com/albums/w2/koolade9/Ibis%20RS4/IMG_9260_zpsprenys8i.jpg
When you remove the little restrictor, vac kicks up quite a bit to ~35cm Hg. The problem is the car’s idle control is tuned to take into account the flow from the factory setup, so immediately things get out of whack:
http://i172.photobucket.com/albums/w2/koolade9/Ibis%20RS4/IMG_9261_zpslbmgfqe3.jpg
Running without the restrictor also creates a ton of flow that the diaphragm doesn’t like very much:
http://i172.photobucket.com/albums/w2/koolade9/Ibis%20RS4/IMG_9264_zpsqlxt1niy.jpg
So we’ve been playing with varying diameters of the restrictor to see if there’s a happy medium with improved flow and stock idle:
http://i172.photobucket.com/albums/w2/koolade9/Ibis%20RS4/IMG_9259_zps2vgmghw0.jpg
On my car, I’m running a slightly bored out version with the restrictor removed to see how it acts under full vac:
http://i172.photobucket.com/albums/w2/koolade9/Ibis%20RS4/IMG_9106_zps0rz4ersm.jpg
Part of the issue is that the breather from the snorkel is there to bring fresh air into the crankcase that is then fed through the oil separator to IM and is a factor in how idle air is controlled. Changing the restrictor increases flow and affects idle. Capping the breather increases vac and also affects idle. There’s a happy medium in there somewhere…
Basically, FWP has been doing all the testing on his car while I play devil’s advocate and provide snarky comments via text. There are still plenty of variables to play with. We’re both leaning toward an aftermarket oil separator to handle the flow while using a bleed valve/restrictor to keep flow at the IM to a point where the idle is solid and fuel trims are happy. We’re not there yet, we’ve got more ideas, but I just wanted to share what we’re messing with. You can thank FWP for all the pictures and data. He’s really driving the development of this. When we have something that works, you’ll hear about it.
