I wanted to get a discussion going about the super lofty redline of the B7 RS4, which revs out to a redline of 8000 RPMs and a rev limiter I believe at 8200 RPMs. I have talked with a few smart people about the mechanics of the high RPMs and it’s pretty incredible.
When you consider that at 6000 RPM the pistons each travel from top dead centre, down and up through the full stroke and back to top dead centre 100 times per second, that’s hard to imagine.
When you consider that at 7000 RPM ut us 117 times per second (!), it’s a level the grand majority of cars do not reach. My old B7 S4 did, and that was pretty interesting. Not many cars see more than 6000 or 6500 RPMs. In talking with a few people on the OEM side the strength and tolerances required to take a motor from 6000 RPM to 7000 RPM are MASSIVE. I guess that’s a good reason for keeping revs down. Many many technical problems have to be overcome, stronger materials, and really when you think about it, just trying to make combustion keep up with the speed everything is moving at is pretty incredible.
When you then go beyond 7000 RPM, on a production vehicle, you are now in rarified air, the task is so large. The B7 RS4 revs out to a redline of 8000 RPM, which means that piston is travelling its full range 133 times per second! When you drive one, to coin a phrase from former RS4 owner richib86, revving it out to redline it sounds like the motor is going to pop. To take a V8 to 8000 RPM is certainly a crzay thing. The 355, 360 430 and 458 V8 Ferraris all did this and beyond, and if you ever hear one, it doesn’t sound like a V8 at all…the pitch is so freakishly high. The RS4 doesn’t get near that, however at 8000 RPM it certainly sounds ‘different’.
The first time you drive an RS4, coming from say a B6/7 S4 with a normal 6800-7000 RPM redline, you first realise that you are shifting WAY too early. I used to shift around 6500 in my B7 S4 when letting it fly. You just get used to the sound/feel/timing of a motor going through the gears, and when you approach your normal shift point you find yourself shifting. I drove an RS4 for the first time a few years ago, and while racing a friend in his S4, my passenger in the RS4 with me kept making fun of me for shifting with 1500 RPMs of usable acceleration left on the table. It’s hard to let it go to 8000.
The new Audi RS4 (B8) and RS5 have an all new engine. It’s still a 4.2 FSI, and it’s still a high revving motor, but they started virtually from scratch when building it including all new internals. One of the reasons behind that was to fix a few things that they didn’t like in the B7 engine, and another reason was to accomodate an even deeper redline. The new variant is pushed all the way to 8500 RPM. An incredible 142 revs per second. I would love to know what they put into the new engine to accomodate that.
Anyway, if anyone can share a little more on the mechanics and difficulties of running a motor out to 8000 or so, please share. Also if you’ve driven any other super revving elite motors, share your experience.
