A few of us have talked about the tendency of the RS4 clutch pedal to get ‘sticky’…sometimes it won’t come all the way up after certain driving conditions.
I have had it happen when I botch a rev-match badly…or when I have been logging the car and ran it to redline in third, then just popped the clutch in and disengaged, rolling along. As I would come to a stop I would notice the clutch might not come all the way up (75% or so) and would get stiff. I was doing some pbox testing the other night testing 60-90 MPH times in different shifting combinations. I found that if I revved 3rd out to past 90 MPH (approaching redline), then popped the clutch and threw it in neutral, this sticky/stiff situation would happen. If I revved out 3rd to past 90 MPH, then shifted into 4th, and kept going, no problem with the clutch…no matter if I got into 4th and kept going…or if I got into 4th and then just let the car engine brake from 5500 RPM or whatever it is, down till normalcy.
I would like to know why it’s happening. Apparently this was more common on the 2007 cars, but my car is a 2008 and it happens once in a while.
the other morning I revved the car while sitting in the parking garage (because I’m a hoodlum and it sounds awesome). I ripped revs up to about 6000 RPMs in neutral. I noticed the clutch got sticky there. I didn’t engage it…I didn’t put it into gear in any way…nothing. This was the clutch situation happening just from free revving the engine while stopped, in neutral.
Anyone have any ideas on this? I was thinking maybe my fluid might be getting knackered and could use a change. First idea.
