I believe it lies between the rivet that popped out and the guide sleeve being all worn down from improper grease AoA says that gets hot bc it’s not high temp rated and the grease gets caked on and that guide sleeve rides on the harden grease which causes it to start shaving the sleeve itself(as shown in the picture)
I tried ruling out the smaller things first. Did a flush, no good
Did the metal slave and SS line, no good.
Also, nobody believes the guy who thinks the race fluid helps? I personally don’t know anyone who has tried that and refuted it yet…
I don’t think sticky clutch is caused by a bolt backing out. If that was the case, it would always be a problem. RS4 sticky clutch as I’ve descrubed it in this thread is intermittent and only under very specific circumstances.
For those who have permanent sticky clutch, there could certainly be a problem with hardware.
I replaced the stage 4 from JHM with another stage 4 bc I love the bite and lwfw. Also keep it mind it wasn’t just the grease(who knows if it even was, but when my tech took it out, it was thick, chunky-the grease giving us the idea that guide sleeve rode on it and causes stickiness)
Also my pressure plate had a backed out rivet just like mistro and that other extea wide body rs4(iirc, Ron?)
Long story short, JHM covered me for a pressure plate and the clutch disc was in great condition.
Yes, but my sticky clutch symptoms seem to be slightly different than most people’s sticky clutch symptoms. Might still be the same issue though with a slightly different outcome.
Solved mine by changing the vacuum line… upgraded version, so order brand new and not a sitting-in-stock item. Mine was ordered in late 2011, removed 90% of the problem.
Interested in more info on the vac line. I know on ls1 cars if you made too much power you jeeded to upgrade your hydraulic lines and that fixed it. Also guys did the slave on rhe car side not the transmission side
