So the oil temp issue…
Upgrading the heat exchanger made little to no effect on high-rpm oil temps. It did drop cruising and <6k rpm oil temps across the board, but not enough for me to recommend the upgrade. After looking at a torn apart BNS motor, I discovered the main oil pump feed is split between the oil cooler block (coolant fed) and the front heat exchanger. If you follow the path of the oil through the block, it has a straight-shot to the cooler block, but the lines for the front exchanger are perpendicular to the oil flow, thus the oil needs to take a hard 90deg cut. Considering fluid will take the path of least resistance, it made sense that at high rpm, the oil was moving straight through the oil block vs. the front cooler. This is where I left off a few years ago.
I finally picked up a block off plate for the cooler block in hopes to force the oil through the oil front cooler only. The risks are potentially lower oil pressure & over-cooling of the oil. On the track, there was (again) no difference. I discovered a small coolant leak that day , got burnt out, and put the car on time-out since April. Coolant leak is fixed and I’m driving the car again. I’ve noticed no difference since having the cooler block removed/blocked off.
I have an oil pressure gauge I’ve yet to install. The intent is to monitor pressure downstream of the oil cooler as a sanity check. That’s the next step.
Once the above checks out, I’ll then swap out the pressure gauge for a temp gauge. My latest theory is that the oil pump is generating all of this heat (not the motor), and the excess is dumped into the pan. Considering our temp sensor is also in the pan this could explain the high temps we see on the dash, while the oil the motor sees is actually being cooled properly (hence the additional temp gauge). I have no real info on our oil pump, so again, it’s just a theory, no data to support it.
My other theory is the built-in oil thermostat has a fail-safe that will bypass the coolers altogether and feed the motor directly under high rpm/temp conditions. This would also explain all the above, but I have no data to support it either.
In other threads, I’ve asked about the dry-sump on the R8 so I could hopefully learn more about the differences between our two oiling systems…there’s even less information about that though.
