If it was a lead acid battery, might be a magic eye showing the state on the battery. Not sure the AGM has one. With a weak battery and/or battery saver should be some codes in VCDS.
Actually, and someone correct me if I am wrong, if your battery is taking charge over that long a period of time you mention, I think it is probably in an OK state.
Well…it could be an old tired battery because after that overnight aggressive effort to charge it, yesterday in the hot afternoon I drove around the local residential area with AC on and the engine just warming up. Could only get two idle “flares” out of maybe 10 stops. [EDIT: so it was better but still not normal] Will go get ECM battery info extracted and I will actually read any labels on the battery.
sounds like the go
Seems that my battery has likely given its best years of service, and would be worthy of replacement. I uncovered the battery topside today and read the BEM CODE label as follows: [EDITED] 8K0915105F and MLA 1304044KBQ, and finally 205 MLA1D44KBQ5. Based on guesses and hearsay on the Internet, this makes me think it was manufactured in 2013 (if “13” indicates the year) or possibly April 2012 if “205” is the code to translate. Can someone educate me here? In any case, it seems I should be shopping for a new battery for this new-to-me vehicle!
I think you may be one digit short in your part number. Have attached a photo of the BEM from my OEM battery I just replaced. That said I suspect you are right about the date. My car was built in Oct 2014 and you can see from my BEM code serial number 141015FCC1 that it is a Oct 2014 battery.
Remember, the part # needs to be a 10 or 11 digit code followed by the 3 digit manufacturer code and a 10 digit serial number. The whole thing including the spaces needs to be 26 characters including the spaces for it to take. If it isn’t then go back recheck your numbers, if they look ok then you may need to add another space on one side or the other of the 3 digit manufacturer’s code.
God !!! Audi make’s it so complex just to change your battery, what ever happened to just changing it over and job done lol !!
I finally went and purchased a Ross Tech VCDS tool and started out by getting Measuring Blocks 18, 19 and 20 to see what the car thinks about my (current) battery state (of mind…). You can see the results below, and remember from my reading the sticker on the top of the battery that I think it is the original from 2013, so 8 years old. I think the Battery Aging is telling us it is about 3/4 of capacity, but in fact the 46ah shown on the bottom line seems to be less than half of the factory battery rating as seen in the earlier posting with photos. I guess it is well due for replacement then, even though there are no obvious symptoms other than that idle surge as described at the beginning of this thread. Will get changed before winter gets here! Now to find a quality 95R/H9 battery in Canada that I can code for the car.
New VW/Audi 95R battery (Varta) installed and programmed with VCDS on Saturday. The idle surge described in the original post has not completely disappeared but is much reduced. I wonder therefore if my 2013 could still benefit from some later engine software revision documented in a TSB that I haven’t uncovered yet. I do know about early transmission rough “bumps” but I don’t have that and that is TCU code anyway.
No success in resolving the original complaint of this discussion thread. The “hanging” RPM when stopping at a traffic light, or stop sign, remains So my thoughts now are to see if there are revised/updated ECM or even TCM factory firmware from what my car has (posted earlier, May 21st) but to be complete, here is what VCDS lists for my 2013 Canadian RS5:
Address 01: Engine (------CFSA) Labels:. 079-907-560-CFS.clb
Part No SW: 8T2 907 560 B HW: 8T1 907 560
Component: 4.2l V8HDZ / H04 0004
Revision: NAH04—
Coding: 1A25003225A6080D3000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM42FSI0118T2907560B 001005
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8T0 927 156 F HW: 0B5 927 156 J
Component: 0B5 42 FSINAR H01 0008
Revision: --H01—
Coding: 000001
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMDL501021 001012
I probably have to book an appointment and somehow get Audi Service to investigate revised ECM/TCM releases, but knowing the “secret handshake” to get to the correct one can be a challenge.
Comparing to my post above you will see under transmission I have revision H03, whereas yours is H01.
I think that is it, as my car does not have the issue.
It could be the mechatronic unit potentially. Maybe check with a specialist of those for the update and repair (even though it is not broken) the way I see it.
dhuddleson, I have somewhat the same issue you have, I would call it an increased idle when initially coming to a stop. This is on the 2014 engine with 26K miles I just installed, along with a 25k 2015 transmission. I have JHM stage 2 software in both.
My 2013 S5 3.0t with DL501 behaves a lot different, throttle off it definitely cuts the fuel until you get to the idle rpm range and then adds what’s needed to keep it at idle. RS5 seems like it adds a little fuel above idle early and then brings it back to an idle after pretty much coming to a complete stop. Granted I only have about 50mi on the car so far but I’ll have to do some more investigating. I’m out of the country for a while and I when I get back I need to drop the engine down 6" as it is to install a new A/C compressor (dam, should have put a new one in before I installed the engine).
My transmission scan, although I think it is the engine software (emissions related).
Part No SW: 8T0 927 156 H HW: 0B5 927 156 K
Component: 0B5 42 FSINAR H03 0005
Revision: --H03—
Coding: 000001
There is only a very small difference between @dhuddleson 's engine scan and mine, though.
If it was the transmission, as I have the latest mechatronic unit in my car, it could be the H03 0010
Thanks for your info Mark and TontoLoid. As I understand, regarding the transmission, the North American 2013 is distinctly different from the 2014 and 2015 model years, as the TCU/Mechatronic was modified/upgraded, so you do see a different part # (hardware). I don’t know if those later (software) SW updates like the H03 0005 or even 0010 can be applied to the earlier 2013 TCU still in my car. And I wonder even about the engine (ECM) if TontoLoid has a completely different tune/part # since I think his is a European car. I think USA and Canada will likely be similar specs, but do they change from 2013 to 2014 and onward? So many variables that our local Audi Service department may or may not know without asking “corporate”…
Good questions, I’m thinking it is emissions related after run in the ECU. My tranny is all 2015 but even though my engine is out of a 2014, I’m using the original 2013 ECU with it. Mine is not a big surge, but much different than completely no surge in my S5, Cayenne Turbo, RS6 for that matter. I’m wondering if every car has it for the most part in the software but most drivers are use to it and don’t really notice it? Maybe for some reason yours is exagerated a little by some other issue? Throttle bodies, O2’s, some sensor (cam, crank, who knows).
Mark, maybe I am just too observant or nit-picky. The “idle up” doesn’t “pull” the car forward or anything, so the gearbox must truly already be fully disengaged clutch-wise. So I am noticing this, but it does not affect driveability or cause concern the car will surge through an intersection.
By the way, I feel your pain for that A/C compressor work. Such a lot of prep work just to get to it… sounds like dropping the V10TDI in the 2004-2005 VW Touareg just to change O2 sensors!!!
If there are no error readings from the scan, no serious build-up there is nothing else to go by than SW/HW (upgrades). I am a bit of an optimist – I think it can be trained away: this are adaptive or learning transmission. Take good care of the car change the filters and so on.
I normally drive in auto mode in the city per the manual, as probably mentioned, never noticed it, at least not since I got the new mechatronic unit.
That touches on another usability thing that might play in, actually. There is an interplay between your driving habits and the adaptation of the transmission to them. So, after a while, this will probably not bother you and at the very least you will get used to it if I am just imagining…
Is your A/C on when this happens? Can you hear the fans? Could be a combination of that AND needing current from the alternator. Mine will do this on occasion and sit at around 900 rpm.
