RS5 - Stabilization Fault, TPMS Fault, and Sport diff Fault
Hi all,
Chasing down what is seeming to be an electrical problem with my RS5. Initially had a code to replace the MAP sensor, after doing so the three dash lights stayed away for a day but are now intermittent. After scanning again with VCDS there was a code stored for low idle which pointed me to replace the purge valve (N80) but unfortunately I’m still getting the three dash lights. I’ve seen similar combinations of dash lights for other Audi models on other forums and the solution usually points to electrical/wiring harness.
I recently scanned again and did notice a stored code for the fuel tank cap Lock and Unlock, Open to Ground. This is referring to the actuator. I have ordered a replacement and cross my fingers that this is the cause.
Any thoughts or Ideas? Thanks in advance!
I inspected the connection point for the MAP sensor but the wiring seems to be in good shape. Curious if this could be battery related? Battery was last replaced a little over five years ago which has me leaning towards poor voltage to particular sensors causing them to go off and on.
Has anyone experienced this or something similar?
I would probably show energy save mode in VCDS if the car had been sitting for a while and some related errors due to systems being deactivated by that. If you have been driving daily lately and since swapping could be the battery, still. If a moist place currently where you are at could also play in although in my case that has knocked out things completely. Intermittent maybe is pointing to the battery. Did you get the Volta factory battery?
Been driving daily, but haven’t actually grabbed a new battery yet as I’ve been trying to pin point the problem. I will be stopping at Audi today or tomorrow to pick one up since the current battery probably needs replacing anyway. I have a picture of measuring blocks for the battery in VCDS and will post it once I have a minute.
Battery life 017-019 is explained in the workshop manuals, which will only give an indication.
Here is my working battery stats from a log last year:
            Address 19: CAN Gateway  (8R0 907 468 J)
13:49:33
37.0 % Battery State of Charge (SOC)
40.0 % Battery State (as shown in MMI)
78.0 % Battery Aging (derived fr. Load)
76.0 % Battery Aging (derived fr. Output)
3.8 mOhm Internal Battery Resistance (actual)
3.8 mOhm Internal Battery Resistance (stan.)
19 Ah Battery Capacity (actual/available)
0.12 Battery Input
I replaced the battery with an OEM Audi battery, but still getting the MAP code and the 3 faults on the dash. Posted on AZ but wanted to document here as well. Posting my scan to see if anybody notices some gaps that I have missed. Thanks all!
02-Auto Trans – Status: Malfunction 0010
03-ABS Brakes – Status: Malfunction 0010
04-Steering Angle – Status: OK 0000
05-Acc/Start Auth. – Status: Malfunction 0010
06-Seat Mem. Pass – Status: OK 0000
15-Airbags – Status: OK 0000
22-AWD – Status: Malfunction 0010
44-Steering Assist – Status: OK 0000
53-Parking Brake – Status: Malfunction 0010
56-Radio – Status: OK 0000
5F-Information Electr. – Status: OK 0000
Address 01: Engine (------CFSA) Labels:. 079-907-560-CFS.clb
Part No SW: 8T2 907 560 B HW: 8T1 907 560
Component: 4.2l V8HDZ / H04 0002
Revision: NAH04—
Coding: 1A25003225A6080D3000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM42FSI0118T2907560B 001003
ROD: EV_ECM42FSI0118T2907560B.rod
VCID: 3B233C3BF3E9D0E39A1-806E
3 Faults Found:
4327 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 135333 km
Date: 2021.05.12
Time: 11:12:17
Engine RPM: 1637.00 /min
Normed load value: 33.7 %
Vehicle speed: 74 km/h
Coolant temperature: 100 °C
Intake air temperature: 49 °C
Ambient air pressure: 860 mbar
Voltage terminal 30: 14.559 V
Unlearning counter according OBD: 40
AFS dm: 57.4 kg/h
Mean injection time: 1.013 ms
Engine operating condition-Channel 87: Part throttle
Relative load value: 21.59 %
Tumg: 21.0 °C
Psr w: 412.73 hPa
Engine torque: 111.2 Nm
4698 - Function Restriction due to Faults in Other Modules
U1113 00 [047] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Mileage: 135333 km
Date: 2021.05.12
Time: 11:12:17
AFS dm: 57.4 kg/h
Mean injection time: 1.059 ms
Relative load value: 21.63 %
Tumg: 21.0 °C
Psr w: 412.81 hPa
Engine torque: 112.0 Nm
9025 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 00 [237] - Implausible Signal
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 135333 km
Date: 2021.05.12
Time: 11:12:17
Engine RPM: 1640.50 /min
Normed load value: 34.1 %
Voltage terminal 30: 14.418 V
AFS dm: 57.9 kg/h
Mean injection time: 1.077 ms
Relative load value: 21.96 %
Tumg: 21.0 °C
Psr w: 417.11 hPa
Engine torque: 113.4 Nm
Readiness: 0010 0101
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8T0 927 156 F HW: 0B5 927 156 J
Component: 0B5 42 FSINAR H01 0004
Revision: --H01—
Coding: 000001
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMDL501021 001010
ROD: EV_TCMDL501021.rod
VCID: 40D94BD79A0FB33BCF3-8014
1 Fault Found:
8448 - Implausible Data Received from Engine Control Module
U0401 00 [109] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 135333 km
Date: 2021.05.12
Time: 11:12:18
Engine RPM: 1629 /min
Transmission input speed: 1629 /min
Transmission output speed: 600 /min
Engine torque: 68 Nm
ATF temperature: 54 °C
Accelerator pedal position: 16.4 %
Clutch status: Kupplung 1 kann Moment übertragen
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8T0 907 379 F HW: 8T0 907 379 F
Component: ESP8 quattro H09 0100
Revision: -------- Serial number: --------------
Coding: 2C1D1A
VCID: 45D75AC385AD9613FC5-8010
2 Faults Found:
01324 - Control Module for All Wheel Drive (J492)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 4
Fault Frequency: 4
Reset counter: 214
Mileage: 135308 km
Time Indication: 0
Date: 2021.05.11
Time: 23:46:33
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x07A2
Hex Value: 0x000F
Hex Value: 0x5095
Hex Value: 0x0000
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 214
Mileage: 135333 km
Time Indication: 0
Date: 2021.05.12
Time: 11:12:17
Freeze Frame:
Hex Value: 0x4A00
Hex Value: 0x4006
Hex Value: 0x120C
Hex Value: 0x46B5
Hex Value: 0x0000
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 GM HW: 8K0 907 064 FM
Component: BCM2 2.0 H11 0621
Revision: 00002001
Coding: 0D804000000000000000
VCID: 015F8ED3D1057A3380D-8054
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Component: J764 ELV MLB H40 0046
Serial number: 2312000116142015
1 Fault Found:
00956 - Key 2
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 204
Mileage: 135157 km
Time Indication: 0
Date: 2021.05.10
Time: 09:13:27
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
Component: 4 Wheel Drive H13 0100
Serial number: 000206120001020
ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
ROD: EV_AllWheelDiffeQSPCAN.rod
VCID: 2F3B186B37913C43269-807A
1 Fault Found:
0059 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [137] - -
[ESP - Steuergerät nicht verfügbar DRC_CAN_ESP_01_SYS_ST]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 214
Mileage: 135333 km
Date: 2021.05.12
Time: 11:12:17
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0178662457
Coding: 01060E9A00FAC00780B0003200000000
Shop #: WSC 06324 123 12345
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000536155
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H03 0220
Serial number: 0123456789ABCDEFGHIJ
Subsystem 4 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H11 0028
Serial number: WA103647000001499767
3 Faults Found:
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 2
Fault Frequency: 7
Reset counter: 254
Mileage: 135039 km
Time Indication: 0
Date: 2021.05.06
Time: 23:19:16
02615 - Fuel Tank Cap; Lock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 253
Mileage: 135039 km
Time Indication: 0
Date: 2021.05.06
Time: 23:19:19
01565 - Luggage Compartment Light (W3)
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 197
Mileage: 135048 km
Time Indication: 0
Date: 2021.05.07
Time: 10:49:39
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 20000000109613
ASAM Dataset: EV_ParkiBrake 001027
ROD: EV_ParkiBrake_AU48.rod
VCID: 38292337C2DFFBFB773-806C
1 Fault Found:
464384 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 214
Mileage: 135333 km
Date: 2021.05.12
Time: 11:12:17
Voltage terminal 30: 14.8 V
Internal Fault ID: 188
Network management state: normal
Function light in parking brake button: OFF
Red operating lamp: OFF
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
Terminal 15 status: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
General Inspection Function: not active
Internal Parking Brake state: Dynamic
Status of parking brake button: Not operated
Status ParkingBrake left: Open
Status ParkingBrake right: Open
If you didn’t already, clear all of the faults and take it on a short drive then rescan.
Just checking but did you code in the New battery with the VCDS ?
Yes coded successfully with VCDS
Have you had a carbon clean or any work done to the car lately?
Just a quick update: I think I have solved the issue by cleaning both throttle bodies. I replaced the MAP sensor which was the original code coming up, and replaced the battery as it was six years old and needed replacing anyway. After almost running out of ideas, I decided what the hell and pulled the throttle bodies off. After inspecting them, mine were covered with buildup. After cleaning, reinstalling, and clearing the codes, I have not seen any codes or lights for 4 or 5 days now.
My thought was the TB flaps not operating properly as the dash lights and MAP code almost always came on at low RPM and when coming to a stop. Thanks all for your help/input!
Cheers
Glad you got it sorted and it was a simple fix of cleaning the TB.
I’ve had mine of 3 times now in the last 18 months and have cleaned them every time !
Unfortunately having this issue pop up again.
I noticed that there sounds like some air coming from somewhere near the oil filter housing and possibly around the PCV valve, but really hard to pinpoint it. Took it to my mechanic to diagnose and they were not able to provide a solution. They likely want to smoke test, and start pulling the wiring harness apart to see if there’s a short somewhere between the MAP sensor and the ECU.
Anybody else dealt with this issue? Any thoughts?
Current DTCs: MAP sensor (replaced), Brake Pressure Sensor (had some water in the connection apparently, but was blown out and not yet replaced). These two keep coming back after clearing.
Hello,
Sorry for reviving this old thread, did you end up finding out what was the issue ?
I was helping a semi local guy that had this map error.
I removed cleaned the throttle bodies then did the adaption. That seemed to work for a short term. After the code came back. I did a smoke test found a decent leak from the intake. Fixed the leak and so far all has been good.
Summery. It seems like even a small intake leak or PCV leak can get this code to come up depending on the outside ambient conditions.
I can confirm the errors come up at the slightest leak. could be in the best case a connector around the manifold not put back in after carbon clean or the intake manifold needs to be torqued. some vacuum hose not fully on.
